Power Steering does not work when weather is hot!!!
My power steering light will on and my car will lose power steering when the weather is cool, warm or hot. Everything will be normal only when the weather is cold. Recently the PS will need a even more colder weather to be normal. Anyone knows where is the problem? Thanks.
It sounds like the pump is worn out.
There is no noisy from the PS. Just the function fail. And when the function fail, the PS warning light will go on.
And where is the cooling tube? |
It's in front of the a/c condensor.
You might want to check the wiring harness to the sensor at the PS pump, it's just under the reservoir. I've seen the inside of the pump and there is no way for the pump to not spin while the engine is running, so even if the pump was worn out, it wouldn't be an all on/off type of failure. I'm not sure what that sensor does, but since we have speed sensitive steering, it might be some sort of actuator that controls the output of the pump. It could be that part that is bad or dirty.
KuoH |
Do I need to remove the reservoir to reach the sensor?
You can see it here. It's the black part just left of center. You can't reach it without removing the reservoir, but you can get to the wiring harness here. Perhaps someone else here will have the information on how to test it. At the very least, you can remove and clean it. You might also want to consider temporarily bypassing the cooler and see if the problem goes away to eliminate the possibility of a clogged cooler. And ofcourse you have checked the fluid level and that it is ATF and not plain PS fluid right?
KuoH |
Is there a diagnostic check for the speed sensitive power steering system? I seem to recall a list of trouble codes somewhere being related to steering components.
