ABS coming on for no reason
Sometimes when I come to a slow stop by ABS will activate when there is no loss of traction. I also hear a cartoon like spring sound when it comes on, like a "doing" sound. Anyone have any ideas?
Re: ABS coming on for no reason
Check your tone wheel. There may be a break or a crack.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
I will check for that. I read somewhere online that low brake pads can cause this. Is this true? I just changed these today.
WOW!!!
that is super scarey to think you have that much stopping power !!!
The wear indicators didn't even make a peep. Another week and I would have had a new wear indicator.
Do you have any binding in the rear? When my transfer solenoid was dying and dead, the ABS would engage all the time because of the back wheels dragging. After I replaced it the ABS issue was gone also.
P.S. I just replaced the rear pads on the '97 and they looked just about like yours. They too never made a sound of warning. Last edited by Blacky; 10-14-2014 at 05:43 AM. |
Low pads won't cause the abs to kick in. I'll bet it's a cracked/damaged tone wheel.
I think you're right. It's still doing it
The worst part is if that's the case, the bearing/hub has to be separated to replace one.
Just take out the ABS fuse from under the dash and enjoy the way a car is supposed brake. Subaru ABS is horrible anyway.
The hub assembly needs to be removed to access the tone wheel for replacement.
Are you getting a code? Could be ABS sensor if you are.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
My LED is flashing 5x, could this just be the sensor? If its the tone ring, I'm just going to grab a whole hub at the junkyard. Seems like an easier DIY. btw it read front Left - Driver side I presume?
Any idea? Ring or Sensor, Driver or Passenger side? I glanced at the ring today and didn't notice any cracks.
