Fuse Box Cover Sticker Help
Anyone know where I can get a SCAN or an actual sticker that sticks over the fuse box (located on the right side on the driver side). Looks like a yellow sticker with a fuse diagram sticker on the cover? Mine is missing, or is there not one? Help!
The whole fuse box cover (with label attached) is available from http://www.subaruparts.com The part number is 82243PA000 and runs $7.38
http://www.subaruparts.com/diag/?mod...category=817-A
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
if you just want to replicate the label...
Thanks! I will order the cover!
JLittell: Do you want a scan of the under hood fuse cover? |
Naw, I'll just order a new one thanks!
Dick ************** 1999 Legacy GT 30th Anniversary Edition 2001 Outback Sport |
Re: Fuse Box Cover Sticker Help
Better late than never.
This is an actual size recreation of the main fuse box cover. Download the pdf file and print it out on photo paper or other stock and use spray adhesive to affix it to the cover. Or keep it in the glovebox as a reference. That is what I did, since my JDM cover is all in Japanese. .
