ABS Unit
I have discovered a small leak somewhere from the abs unit. I shall be removing the unit shortly. I post here to ask if there are any o rings or seals which could possibly be the cause. It isn't causing concern yet as it's only a weep and brake performance us normal with no codes or flashing lights but I would like to know if there is a procedure for taking it apart. I have searched here but there doesn't seem to be much about it. Thanks in advance.
Re: ABS Unit
i rebuilt one on an outback once. it was nothing but a bunch of o-rings. they tend to leak from the little round plugs on the side of the unit. on the outback you push the plug down to access a snap ring then a spring will push it out. replace the o-ring and put it back. i would take it apart as little as possible.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
