Old 09-28-2013, 02:33 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Dynomat or similar
Anyone used any types of insulation to lower road noise? After installing all-metal coilovers, road noise has become a bit obnoxious. I think using dynomat would be best, but it's way too expensive. A lot of people say they use that peel n stick stuff from Lowes or Home Depot because it's affordable. Anyone here used anything similar? I also don't want anything that produces a fowl odor...
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 09-28-2013, 02:59 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Dynomat or similar
B-Quiet from Canada is cheaper and reports like it as well as Dynamat
Old 09-28-2013, 09:31 PM
Tapani Tapani is offline
I used a ton of these products.... they performed very well in a comparison test (Dynamat + others).
http://stp-distribution.com/ (made in Russia (!) and may not be available in the US).
So far I've done only backwards from under the rear seat (20 kg of material), but with very good result. Tire noise was reduced significantly.
I also used the SPL polyurethane foam (10mm) behind all trim panels. No rattles.
Tapani
Old 09-29-2013, 01:13 AM
sabin sabin is offline
Banned
I've used B-quiet a couple of times and it works well and is cheaper
Old 09-29-2013, 04:16 PM
scoobydrvr scoobydrvr is offline
The stuff from Home Depot was discussed at length on the CR-Z forum when I was an owner. DON'T USE IT! On a hot day your car will smell like a roof getting re-tarred and the stuff will start to peel off. It wasn't meant to be put in cars.
1996 SVX LSi : Work in progress, future garage queen
2013 Acura TSX: Mistake
