PnP heads while doing head gaskets
So while I had my engine apart to do headgaskets I decided to sit down with the heads and do some mild port and polishing work, I know its a little rough in some places but my machine shop said they were pretty good for a home job. These are not off the motor in the car but a spare motor.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
Re: PnP heads while doing head gaskets
![]() ![]() ![]() ![]() Dyno sheet coming soon.
Bishop did you ever finish/install this engine? Dyno sheets?
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
finished installing the engine, sadly never got a chance to do dyno runs as the radiator failed catastrophically leading to a really bad overheat. I havent had a chance to start digging into the engine yet to see if it failed at the headgaskets or if the heads themselves warped.
