NJ Emissions
New Jerseyites may know that there are 2 types of private AWD emssions sniffers out there. The new type measures HC and CO at idle and 2500 rpm. The old type measures only at 2500 rpm. I previously had been going to a guy with the old type. Failed on his. Got YT to retune the Hydra for higher FAR at low rpm's and low throttle. But my local guy's machine broke. Went to a new guy with the new type of machine. Passed with flying colors at 2500 rpm, failed at idle. Does anyone know of any garages or service stations in NJ still using the old machine?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
