shut off alarm system for good
How do I just turn off the alarm system so it doesn't work .... Unless I want to turn it on again some time a few months from now??? Not looking at a wire cutter here... jsut some switch that works to disarm it for awhile...
Re: shut off alarm system for good
press the security switch so it is not lit up. It's on the left of the steering wheel just below the guages.
Tried that.. It keeps lit all the time...
Ok so no matter what, every time you press the keyfob button the horn beeps as the doors lock? When the system is unarmed it will just lock and unlock the doors with the button, no beep.
So I guess the central theme here is whether you have tried the keyfob before and after pressing the button (try doing it with a little force). No change, try replacing the security switch or opening it up and cleaning the contacts. |
dcb |
Security on = 1 beep arm, 2 beeps un-armed Security off = 3-4 beeps when locked and unlocked If your security light is on all the time, sounds like a problem with the module? Does your remote work? Is it stock?
If your car has dual airbags the alarm module is easily accessable on the roof of the trunk. Unplug it. On the earlier cars it is hidden behind the glove box.
Christian- 96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC. 2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock 1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods 2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock |
![]() With all the other electrical oddities from the prev. owner, im somehow not that surprised ![]() |
Ah ha!!! I don't have a remote with the car.... Can I buy one of those generic remote keyless entry things that are sold on ebay and use that or ideas on where I can get a remote??
Then what... I bet it is a pain to figure out how to program the keyless entry.. Also, how do I post a picture of my car??? |
Hey... I think I loaded the picture!
Try again to see if a picture will show better...
![]() Oh, it isn't hard to program it at all. Look in the How-To Documents for the instructions. ![]()
