Old 05-18-2006, 07:34 AM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
Automatic Transmission Parts For Sale
Not that many of us do transmission repair, but if you are, I have the following Automatic transmission parts for sale.
Please PM me if interested in any transmission parts, other then forward clutches. Here are just some of the items. All are in perfect condition. The diff is gone.
- Torque converter
- Trans Resistor (behind battery)
- Shift Level (interior)
- Trans Computer
- Shift cable
- All solenoids
- Transmission pan
- Dipsticks for Diff and trans
- Switch on trans for (P-R-N-D-3-2-1)
- Brake Band Assembly
- Valve body
- Trans Extension (Speed sensor, Transfer Valve)
- Clutch Drum assembly
- Oil Pump
- All gears
- Reverse Clutch Assembly
- Differential case
- Input Shaft
- Differential gear and transfer (pinion) gear - SOLD
Thanks
Old 06-01-2006, 10:50 AM
Brian's Avatar
Brian Brian is offline
Do you have the rubber transmission mount? How much?
Old 06-07-2006, 11:12 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
how much for sol. C... i think it should fit a legacy...
- John
Old 06-13-2006, 08:35 PM
svxcuseme's Avatar
5 speed 4 sure
Sorry for not getting back on this until now. PM Sent
Old 06-25-2006, 12:52 PM
svxcuseme's Avatar
5 speed 4 sure
Still for sale ...
- 1992 - SVX Drive Shaft
- 2002 - WRX Drive shaft
- Torque converter
- Trans Computer
- Shift cable
- All solenoids
- Transmission pan
- Valve body
- Oil Pump
- All gears
- Input Shaft
- NSS Switch on trans (P-R-N-D-3-2-1) - SOLD
Old 08-23-2006, 06:55 AM
svxcuseme's Avatar
5 speed 4 sure
Bump ............ Still for sale
Old 08-27-2006, 05:20 AM
Wocketman Wocketman is offline
All gears?
I'll be asking you for some of those gears...;-) Just need to check with the shop on exactly which one(s) I munched.
Also justed posted on another thread, so I'm obviously on the hunt...
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 08-28-2006, 07:19 AM
Front diff??
Ok, apparently what I need is nearly everything in the front diff. case: ring & pinion, side shaft gears (stub shaft), etc. Don't necessarily need the case.
They asked me to be sure to check the gear ratio...to be sure it's stock.
Still have this? If so, please email me at ocean.planet@earthlink.net.
Bruce
Bruce Schwab
www.bruceschwab.com
Old 10-05-2006, 07:47 PM
svxcuseme's Avatar
5 speed 4 sure
Please PM for requests. I rarely check this post.
Nope diff is gone but other parts stil for sale. Thanks.
- Torque converter
- Shift Lever (interior)
- Trans Computer
- Shift cable
- All solenoids
- Transmission pan
- Valve body
- Oil Pump
- All gears
- Input Shaft
- Differential gear and transfer (pinion) gear - SOLD 06-13-2006 08:35 PM
Old 10-05-2006, 09:56 PM
how about the innder transfer drum and the sun gear that mounts on the rear of the pinion shaft?? I need these drive gears so they can be modified
Old 10-28-2006, 05:14 PM
deputymarshall deputymarshall is offline
transmission resistor behind battery (solenoid A)
Do you still have that resistor? [And, I assume, that when you had the automatic transmission in your car you didn't have the power light blinking/transmission code 11...meaning the resistor was working.]
I'm about to build one out of an off-the-shelf resistor...but I'd prefer stock because it's easier to mount.
Best,
-jim d.
Old 11-01-2006, 07:56 AM
svxcuseme's Avatar
5 speed 4 sure
Sorry for the delay.
Resistor - $45 shipped - It's perfect. No blinky light... measured resistance was like new.
Gear and drum - Tom, I have the sun gear. About the other part...What # are you looking for in the pic below? Assum?
Old 12-07-2006, 08:17 AM
svxcuseme's Avatar
5 speed 4 sure
Please PM for requests, thanks.
- Torque converter
- Trans Computer
- Shift cable
- All solenoids
- Transmission pan
- Valve body
- High Clutch assembly
- Oil Pump
- Input Shaft
- Planetary Gear Assembly - SOLD
Old 01-07-2008, 11:57 AM
svxcuseme's Avatar
5 speed 4 sure
Anybody still need tranny...anyone? ...anyone?... parts
Old 01-15-2008, 03:52 PM
Maxo's Avatar
Maxo Maxo is offline
Yes, now I do.
Just found out that my clutch drum is sheared off... so you have what I need?
