Old 04-16-2009, 12:04 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Question vibrations when i turn...?
my car drives great untill a certain speeds are mixed with certain degree of turning and i get vibration in the steering?
could it be wheel balance?
or is it a lil more technical and exspesive then that...?
do bushings have anything to do with steering cause my front ones are gone (pickin new ones up from motorsport once my i get my new altornator)
this has been happenin for a long time...but happens usually at highway speeds (50-85)
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 04-16-2009, 01:43 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: vibrations when i turn...?
Could be both. Two out of balance wheels on an axle will have different degrees of vibration depending on where the position of imbalance is relative to each other. Bad bushings allow excessive play and can cause the same thing. If the tires are still good, id get them rebalanced as wear will change the rubber content and nullify the weight balance applied when newly installed.
Old 04-16-2009, 04:14 PM
VICSVX's Avatar
Never Forget
ok, i'll do that this weekend then and see what happens
thanks So-Cal
VICSVX
