Old 12-28-2007, 03:19 PM
Nomake Wan's Avatar
Nomake Wan Nomake Wan is offline
Retired
Send a message via AIM to Nomake Wan Send a message via MSN to Nomake Wan Send a message via Yahoo to Nomake Wan Send a message via Skype™ to Nomake Wan
Need an answer, QUICK!!
Okay guys, here's the situation. I went to NY for Christmas. Left the SVX in the parking lot in California, took keys with me. Due to a slight blunder, the keys are still in NY but I'm in the airport in PA already on the way back to CA.
Now, I locked and alarmed the car using my remote (the SVX has a stock security system, OEM). I do have another key to the car at home, but not another remote. Also, the only door which can be unlocked by the key is the passenger's door (the driver's door and trunk locks are seized).
If I unlock the passenger's door with the key and attempt to start the car, will it work? Or am I totally hosed until I get my set of keys back?
Thanks in advance!!!
Old 12-28-2007, 04:02 PM
If it is a stock alarm you will be able to start the car and disable the alarm with the key in the ignition.
Old 12-28-2007, 04:27 PM
crazyhorse's Avatar
242,000 mi on oem trans
Be prepared though, it will go off. My understanding of the stock alarm is, however you lock the car, key button, remote, ETC, if you unlock it a different way, the alarm will go off.
Starting the car with the key will silence it though.
"42"
Current Stable By Age:
Old 12-28-2007, 04:32 PM
Well I figured it'd be obvious that it would go off.
Old 12-28-2007, 05:08 PM
crazyhorse's Avatar
It wasn't to me, when I locked my car with the console switch, then unlocked it with the key, I was like WTF!
"42"
Old 12-28-2007, 05:25 PM
Imagine my surprise when I was under the hood of the Laguna with my head over the horns...
Old 12-28-2007, 08:24 PM
Did it get your attention?
Yes, I have done this before. Locked it with the fob and then unlocked it with the key. The alarm sounds, but when you put the key and start the car, it silences it.
Old 12-29-2007, 01:25 AM
Hondasucks's Avatar
Subaru Technician
If it is locked with the remote, and the security system is active (red light blinking) the alarm will go off when you unlock the door. Put the key in the ignition and press the parking light switch. Once the alarm stops honking, you'll be able to start it.
(This is what the service manual says, YMMV)
1986 VW Jetta
