no STi 2.5L motor swaps yet?
I know the EG33 is super smooth, but I had always figured that if I really wanted to go for the big power in an SVX, I would go with a 2.5L STi motor. And now that the late model Subaru ECU have been cracked, anyone who has a copy of ECUFlash can tune the stock ECU making a 2.5L swap even less expensive and easier. I guess no one has done this yet?
BTW, I've heard that with some basic tuning, the 2007 2.5L STi motors are cranking out 350+ ft-lbs of torque. Crazy stuff. The stock turbo still poops out at around 330 whp though.
Wiring = nightmare. That's why there aren't many swaps going.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
But still, the SVX nose would be lighter, hence the car would be more controllable on high speeds and possible drifts
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
Somebody fund me, and I'll get right on it...
Someone in the northeast has done it. I can't recall their board name, but it has something to do with sti??
I don't recall any posts about it being complete...did thry ever get it on the road?
Yeah, that's another good reason.
I dunno if the STi's DCCD gearbox can do the trick also with the EG33 by converting most of the partition to the rear wheels...
I still need to read about it..
yeah id consider it if i even knew where to get started as far as the wiring goes. im going for nitrous on the eg33 first and when i want more ill go ej25 but currently its not worth the time or money to me considering i just swapped in a low mileage eg33 last year.
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
SilverSpear: TomsSVX has the DCCD in his car... I think people will tell you it works just fine.
![]() The one person I saw with a swap going was into a laguna blue... but I don't recall any posts about it being finished. They just dropped off the face of the boards. For those interested, the thread is here: http://www.subaru-svx.net/forum/showthread.php?t=38108 |
^^^^that wasnt the ej25 from the sti either unfortunately
Well crap it's the only one I've seen and even that didn't get finished.
Oh really??? I still remember arguing with Tom about the possibility to plug in the 6 speed with DCCD into the SVX... he insisted that it won't work and WILL NEVER work... I wonder how he was able to convince himself of the opposite... ![]()
![]() Tom |
Hey Tom.... hows that dimmer
1991 SVX L JDM |
