whining sound when i press on gas
hey
my 93 SVX makes a weird whining noise when i press on the gas and it increases in volume/pitch as the RPMs do what could this be? it has done this before but only on occasion, now it is every time i drive the car and it is getting kind of annoying anything i can do to fix it? thanks |
Sounds like an idler going bad or maybe power steering? Take a listen and see if you can find the general vicinity of where the noise is coming from.
Depending on what the "whining" actually sounds like, it could be an exhaust leak.
i just replaced my power steering a couple months ago
i will check where the sound is coming from later, but i do not have an amplifier installed, everything is stock what would it sound like if it were an exhaust leak? |
Check all your vacuum hoses too.
I cant really describe the exact sound of an exhaust leak, but what you should try would be warm up your SVX, leave the door open, stay in park and hit the gas, and if the sound is coming from directly underneath you, it would probably be an exhaust leak.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
If you have a younger sister, you can have her take the bus to school. now you can accelerate as much as you want and not here whining.
(Sorry, couldnt help myself) If it's an electrinic, "Your grandma's old tv withy the volume all the way down" kinda whine, its alternator whine. I have NO idea what causes this, but Im sure Trevor does. If its more of a mechanical thing, I'd suspect first a bad bearing on the power steering pump, ac condensor, or alternator.
hmmmm yes...sounds like you need to replace your muffler bearing:
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 12-20-2006 at 07:13 PM. |
Could be your tires...Mine make a higher vibration whine...I think a belt shifted inside the tire tread...I rotated the tires and the sound minimized from the front where it was originally coming from.
could it be from a tape ipod adapter?
after i took it out i didn't hear the sound but i only took it once around the block and back, so i don't know if its really gone...will update later thanks |
