Underdrive pulley WOBBLES?
I've never seen anything like it. After replacing my stock pulley with a new aluminum underdrive pulley, and putting on new belts & torquing the new pulley to 100lbs, I thought I was all done. But when I start it up, the belts run smooth on all the pulleys and tenioners, except the crank pulley that I replaced. It's wobbling around like it's going to fall off. I'm afraid to drive it to the Dragway 42 meet next wekend like this, since it looks like it could throw a belt at any time. I haven't taken it all apart yet, but I figure it must be one of two things:
either I didn't get the pulley onto the key like I thought I had (but I was almost SURE it was locked on); or the pulley itself is not balanced. I'm going to remove the belts, start the car, and see if I've still got the wobble. If so, the I guess I'll take off the pulley and spin it on a shaft to see if it's out of balance. Am I missing some obvious problem here? ![]() Thanks, Cappy
Cappy '94 LSi Barcelona Red 158,000 miles '92 LS-L Dark Teal 47,000 miles '95 Olds Acheiva 104,000 miles '85 Audi 4000 135,000 miles '87 Supra 129,000 miles - 2nd JDM engine |
also what brand is the pulley? did you get it off eBay? *cringe*
I DID get it off ebay. Not good, huh? The guy has a 100% positive rating??? Of course if it turns out to be unbalanced that will drop to 99%. Darnit! I thought I'd save 50 bucks and get the cheapo instead of the Unorthodox racing one. So you're telling me THAT could be the problem?
Thanks Budfreak. Let me try to make sure it's on the key OK and not out of balance. If I have to I'll put the old pulley back on.
![]() ![]() I got mine on ebay about 40,000 miles ago. Never a problem! I did tighten it down GOOD though. Good luck |
Thanks,
It's definitely on there tight enough, and it isn't moving on the shaft. I either put it on crooked, or it's out of balance. I'll get a chance to work on it tomorrow & let yo know. And YES, Budfreak, I was trying to get a few extra ponies in my car so I wouldn't be too embarassed Saturday at the track ![]() ![]() Cappy
OK It's Official...I'm an IDIOT!
Took the pulley of today, and guess what? I MISSED THE DAMN KEY by a 1/4 inch!
![]() ![]() Thanks for the input. I feel like such a goof! Well, now that I screwed up the $40 pulley, I guess I can go ahead and order a higher quality one. Next time I'll be more careful. ![]() Cappy
![]() P.S. Mine will still be faster. ![]() ![]() ![]() |
