Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 07-04-2004, 10:10 PM
dragon8504 dragon8504 is offline
Send a message via AIM to dragon8504
new exhaust
i am thinking of putting on a completely new exhaust. since my muffler already needs to be replaced. i am not sure if i should go high performence or what. i would also like to know what class the high performence exhaust system would put me in in relation to scca solo2 rules. what pipe size, cats, and mufflers do you people suggest???
Old 07-05-2004, 01:06 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: new exhaust
According to SCCA Solo II class rules, you can add any exhaust you wish aft of the catalytic convertor(s) and remain in G Stock.
A high performance muffler from Magnaflow or Flowmaster will be less restrictive than the stock unit and cost much less. If you don't want a loud and raspy sound, get a high flow resonator from Dayle (MotorSport SVX). A 2.5" system using the stock layout will return the best results - anything larger will cause a loss of low end torque.
-Chike
2006 Steel Gray WRX TR (sold)
Old 07-06-2004, 12:33 AM
mbtoloczko's Avatar
sans SVX
If you want some info on sound levels and flow rates of some aftermarket mufflers, have a look here:
http://www.ls1sounds.com/faq.htm
The OEM tubing size after the secondary catalytic converter is about 2.36" ID. 2.5" OD tubing (OD is the standard for measuring exhaust tubing in the USA) has an ID of about 2.4", so its a good size to use for a cat-back system.
If you are making your own exhaust and are anticipating some bends in the tubing that more than 10 deg, you may want to consider using mandrel bends. Helps flow rate.
Mychailo
Visit my locker
Old 07-06-2004, 08:27 PM
Dober
anyone know if its possible to remove the catalitic converters on the y pipe and just put a turbo catalitic converter on? mine arn't too good and i heard theres a way to have just one major catalitic converter and pass inspection. please get back to me
Old 07-06-2004, 10:57 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You're going to have a problem getting any muffler shop to remove the existing cats without replacing them -- your best bet it to replace them all with high flow versions (Magnaflow makes them and I think Flowmaster does also). I've also read that the cats from Mustangs work. I just had the secondary cat replaced with a Magnaflow 2.5 inch high flow cat along with a 2.5 high flow resonator. Sound might be a tiny bit louder/deeper than stock.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-07-2004, 08:51 AM
Chiketkd's Avatar
Agreed. The high flow cats from Maganflow work very well with our cars. Bill is also right in saying that no shop will just remove your cats w/o some replacement going on in it's place.
-Chike
Old 07-14-2004, 07:19 PM
exactly which seriers and sizes am i looking at from magnaflow and flowmaster? what do you people like or have in your SVX's?
Old 07-14-2004, 07:28 PM
Merz's Avatar
Merz Merz is offline
halfsharkalligatorhalfman
Would replacing the cats with straight pipe have the same performance improvements as replacing them with high-flow cats? It would be a lot cheaper to buy straight pipe than high-flow cats. I would be doing the welding myself, so I wont have to worry about whether the shop would remove the cats.
Thanks
`92 pearlie 220k
Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley
'00 GMC Sonoma ZR2.
Old 07-14-2004, 09:10 PM
SVXRide's Avatar
It really gets down to whether your car is still "emissions legal" after whatever mods you do. If your state doesn't have annual emissions tests, then you could legally remove the cats - you just have to rationalize in your own mind what you're doing to the air you breath. A high flow cat is going to be more restrictive than a piece of straight pipe, but by how much more I'd have to sit down and do some flow calculations first..
-Bill
p.s. you also should be aware that more and more autoX governing bodies are imposing noise limits on all cars running in order to keep their course sites (i.e. neighbors start complaining if things get too loud) I think the upper limit tends to be around 95 dBs.
Old 07-14-2004, 09:55 PM
SVXObsessed SVXObsessed is offline
Noise Limit!?
If that gets enforced (or is it already enforced?) in WA im screwed!
1992 Subaru SVX LS-L --Pearl White; Bought 12/2012 with 39,000 Original Miles
2012 Subaru Forester -- Marina Blue Pearl; Daily Driver
1993 Subaru Legacy L Wagon -- Winestone Mica; Lifted on Forester Suspension
2004 Subaru WRX -- Platinum Silver Metallic; Sold 2011
1995 Subaru SVX LS -- Brilliant Red; Sold 2006
Old 07-20-2004, 08:00 PM
what are the dimensions of the stock mufflers?
and what other setups are out there?
Old 07-20-2004, 08:49 PM
mbtoloczko's Avatar
sans SVX
The only ready-made exhaust system for the SVX is the Stebro exhaust. Everything else must be hand-built.
Mychailo
Visit my locker
