rear differential mount
Aloha,
My technician has pointed out that the rear differential bushings are bad. The rubber has failed. He claims that this is the reason we hear a chirping noise every now and again from the rear when going over bad pavement or even when closing the doors. I have looked on Subaru parts website but cannot find the parts on any of the rear suspension or rear differential schematics. got any ideas as to what I should be looking for? A part number would be very appreaciated. Also if the rear diff is suspended at an odd angle because of the mounts being bad, would that throw off the allignment? The allignment shop says everything is within factory specs, but she still drifts to the right Front suspension continues to give me some greif -- new tires, motor mounts, struts, helpers and spring seats are great -- however I still feel every variation in the road. She just does not feel as sure footed as when new -- or even a few years ago. My tech says he will retourque everything in the front to make sure all is tight but after that he is out of ideas. Springs? Stabiliser bars? Other rubber bits to change? Finally the interior creaks and rattles are getting silly. Anyone had experience with the rubber bits that keep the plastic parts quiet? Mahalo in advance for your response, much Aloha Nick |
I can't help you with the bushings. I know mine needs bushings in the rear as well.
I have a little rattle in the front end when I close the doors. Sounds like a squeek. As for the alignment I would suspect the tires. It's amasing how much incorrect tire pressure can affect the handling. I can tell right away when one tire is low a few psi.
Kuoh
Thanks for the diagram and part number - that is the part. Will order today. Nick |
I'm having the same problem (as Nick in Hawaii) with identifying replacement rear differential mounts. Could you repost your link to the information above (the link is not active) Regards and thanks Reece [from the Land Downunder] |
If you experiance a pull to the right your cv joints may be going bad. Check the condition of the cv boots and see if they have been comprimised. Another way to tell is if you hear a clicking noise while turning sharply at slow speeds.
"oh blessed mother of acceleration don't fail me now!"-Dan Ackroyd: BLUES BROTHERS '92 Teal LS-L Sold to North Carolinaians! 1972+'73 BMW 2002 tii('72) someday I'll finish restoring them,...someday (for sale) |
Rear Differential Mounts - Part Number
For all those who need to replace the two mounts at the back of the rear differential the part number (not listed in the Subaru parts diagrams) is:
41322PA000 and you guessed it .... they're unique to the SVX. In Australia they are available through Subaru Dealers (special order from Japan) at about $50 AUD each. If you notice excessive bumping in the rear during gearchanges and/or when doing full-lock turns - yours may need replacing. With age the rubber perrishes and eventually tears allowing the rear of the diff to move up/down when torque is applied (during gearchanges, accellerating or when the viscous LSD is working hard - ie, full-lock turns). |
pulling to the right
My mechanic said that a LHD car is designed to drift to the right so that if you fell asleep you wouldn't hit opposing traffic. So how much is too much? A normal alignment wasn't enough to give me just a slight drift to the right, so the alignment shop found the sub frame needed to be shifted and they did. I find it hard to believe that there was enough slop in the mounting holes to allow it, but it was better afterwards.
WHAT????!!!! I can't believe any car would be disegned to pull to the right in case you fall asleep at the wheel. Could you imagine the legal ramifications of that policy if true? Your mechanic is pulling your chain. Some cars paticularly sports cars have sensitive steering system that will pull to the side of the that the "crown" of the road is. The crown is the direction that rain water would flow. Try driving your car on a 3 lane highway and you may notice that in the right lane it pulls to the right, the left lane pulls to the left, and (lo and behold!) the middle lane in the center should not pull at all. If it does it means wheel alignment, low tire pressure (or un even), or at the worst it is possible your cv joints are failing. This would be most apparent if wheels turned all the way one direction or the other and you hear a faint clicking noise while driving slowly. Good luck.
