Old 06-11-2004, 07:36 PM
ilsegretosvx
Cooling fans on radiator
Both of my fans freaked out at the same time. I took both of them off and called the dealership to see what I needed. Now bear in mind that both of them are identical even the part #s on them. The dealership tells me that the ac fan is differnet than the radiator fan, but Im sitting here with the same friggin part on both sides. Does it make a diff, does one spin faster thatn the other??
Old 06-11-2004, 07:58 PM
red95svx
they are different by 1 number!
Take another look. The part numbers for both fan and motor assemblies are only 1 digit different from each other, so if you look quickly you might not notice the difference
The assemblies do look similar, but they are different. I think one might draw more air than the other, but I really don't know.
If I were you I'd be looking at fuses and wires. Losing both fans at the same time is a sure sign of an electrical problem (bad ground, bad power, bad fuse) and not the fans themselves.
Old 06-11-2004, 10:41 PM
ilsegretosvx
they are exactly the same. The only difference is the fan blade is one has 5 and one has 6 blades, and opps I didnt look when I put it back on
Old 06-11-2004, 10:59 PM
SubaSteevo's Avatar
No longer blue member
I needed to replace one of my fans, and only one type was available (I think the 6 blade one). Either will work, not a big deal.
-Steve
01' MSM Lexus IS300
Old 06-12-2004, 05:50 AM
red95svx
So the difference is the number of blades. Funny. Does the 6 blade fan push more air?
Old 06-15-2004, 12:54 PM
rad fan
Does the passenger side fan work when the air conditioning is on?
Old 06-15-2004, 04:45 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
It should come on whenever you use the A/C or defrost.
