Old 08-25-2008, 06:23 PM
95greensvx's Avatar
95greensvx 95greensvx is offline
Engine stuttering at low rpm's
I recently purchased a 92 SVX with a 5 speed manual swap. When I drive the car and begin to start in 1st gear and accelerate from 1000 rpm's up to around 3000 rpm's the engine feels to stutter, such that it's like it's not getting the proper fuel ratio, but once it gets around 3k or higher it runs smoother. This tends to do it in 1st and 2nd gear mainly, and sometimes in 3rd gear depending upon where I drive and how I shift it.
I am not sure why it would be doing this. Any help and/or info would be greatly appreciated. Thanks in advance.
Old 08-25-2008, 06:27 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Engine stuttering at low rpm's
Trans mounts?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-25-2008, 06:29 PM
95greensvx's Avatar
I guess that could be a possibility, I haven't had the chance to look everything over.
Old 08-25-2008, 07:52 PM
major7venth's Avatar
major7venth major7venth is offline
M7
Maybe start with checking for error codes? Maybe change the plugs.
Old 08-25-2008, 08:05 PM
95greensvx's Avatar
That's the first thing I'm going to do. I am hoping that solves the problem, will find out next weekend or the following weekend when I can get the time to replace them.
Old 08-25-2008, 08:36 PM
svxpert svxpert is offline
does it do it when its out of gear?
Old 08-26-2008, 02:11 PM
95greensvx's Avatar
No, it's only when I have the transmission engaged and am accelerating.
Old 08-26-2008, 07:16 PM
Frank Rizzo Frank Rizzo is offline
Banned
Propbably an igniter coil on its way out.
Old 08-26-2008, 07:44 PM
95greensvx's Avatar
Hmm I haven't thought about that, how difficult is that to check and replace as needed?
06 Ford F150 Crew 4x4 142K+ miles
05 Volvo XC90 163K+ miles
02 Toyota Camry 170k+ miles
Old 08-27-2008, 11:27 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
durring accelration... but only in first gear... or in all gears?
- John
Old 08-27-2008, 12:12 PM
95greensvx's Avatar
During acceleration in at least 1st and 2nd from 1000 to 3000 rpms. When I shift to third gear sometimes it does it when I'm below 3000 rpms.
Old 08-27-2008, 05:44 PM
Banned
If that's the case, the problem will progress to misfiring at idle and while in park. At that point it should be more easlily diagnosed by disconnecting ignitor coils one at a time and starting the engine. If the shaking gets worse, that's probably not the one. If the shaking gets better, it's probably the one on the opposite side of the engine in the same position. The front ignitor coils are easliy disconnected. The back ones not so easy. Start with the front ones.
Old 08-27-2008, 07:50 PM
95greensvx's Avatar
I will check everything out this weekend when I get home from being away at work this week. Thanks for all the info.
