Wow what a car !!!!
Been sitting on a trickle charger since October. I have a date on Thurs . Said I may take the car. .took off the cover. Opened the door. Stepped on the clutch turn the key and it was running. I did just barley hear the starter.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Re: Wow what a car !!!!
It was die'ing to get out of the garage and into the sun!
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
I had the same experience. Car was parked in a cold garage since November.
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, |
For those of you who keep the car in the garage all winter, do you perform any special pre-start procedures before first crank? For example, manually turning over the engine to lube up the internals. After a months of sitting, all the oil must be at the bottom of the engine and the idea of that first start just makes me cringe.
I also keep my car in the garage all winter and make an effort to start it and let it idle in the driveway on decent days to try to keep those 'dry-starts' to a minimum.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
The plan was to have it crank. Unfortunately it did not I shut it down after a few seconds and let it rest. Restarted. Oil pressure came up instantly. Fig all thirs new cars in the dealer lots. Sit months with 4 miles on them. They don't prep them. At the Subaru factory. It comes off the production line onto a dyno and revd to 5,000 RPM. I saw it with my own eyes.
Whenever my SVX has been sitting for a while, 6-9 months, I just disconnect the igniter back on the firewall and crank it for about 20 seconds to manually move the oil without starting ( the oil light actually goes out) Then plug it back in and it fires right up. Stays connected to the Battery Tender when not driven. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 04-15-2018 at 02:22 PM. |
Where is the igniter you speak of located SVX Mage
Filled my motor with 6quarts of oil/ 2 quarts if mystery oil Last time I changed the filter and ran it about half hour total about 4 months ago have not started it yet and would to mush it around before I start it |
