stainless steel brake lines & brake fluid
I'm in the market for both of the above. I have settled upon Dayle's brake lines and ATE Super Blue. Does anyone have some proven testimonials on these or better+cheaper stuff? Not lesser quality cheaper, only less expensive and not homemade! Thanks-Mike
Check that the fitting installed on the lines match up exactly with the stock SVX mounting points (I'm talking about the attachment points on the strut housings, not at the caliber and hardline). I know the SS line kits from RaceConcepts do (at least the ones I bought for the front and back brakes did). As far as fluid goes, I think many of us are using the Valvoline Synth fluid with no issues.
Make sure to thoroughly bleed your entire system when you change out the lines. -Bill
I'm not on good terms with raceconcepts as of yet
I like using the ATE Super Blue. I interchange it with the ATE Gold once a year. That way I can always tell when I have completely changed my fluid.
I am also using the Goodridge S/S lines from Precision brakes, the slotted/dimpled rotors from RaceConcepts and Akebono Pro-ACT ceramic pads all around. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
How were Precision brakes to deal with? I have been getting screwed alot lately. Do you have a link? The goodgidge lines have zinc plated fittings correct? How are they holding up to the weather? How much were they. Did you have to buy different clips for the strut mount.
I bought mine on e-bay from irotors. They cost me $125 and they are very good. I tried buying from other places and the prices were ridiculous.
As far as fluid goes, unless you really work the breaks hard DOT 3 will suffice. I tend to burn up DOT 3 and on previous cars even vapor locked my brakes a few times.....boiled the break fluid which causes it to expand and lock the brakes. Anyway, if you're like me then the higher DOT ratings would be the best way to go. By far DOT 5.1 is the top of the line. The military used to use DOT 4 silicone synthetic fluid but had too many problems with moisture contamination. Whatever you decide, stay away from any fluids containing silicone. Here's a link that will give you some good info on brake fluid: http://www.synlube.com/brake.htm |
