Old 07-23-2004, 06:03 AM
afsquid
fuel gauge
What's up with the fuel gauge? I now have to go by the odometer on when to fill up. Is there an easy fix out there? It's always showing lower than normal now.
afsquid
'92 grn lsi
Old 07-23-2004, 06:13 AM
dcarrb dcarrb is offline
It's apparently a typical SVX characteristic. Doubt there's any sort of fix. Nevermind the odometer; just note how many gallons the tank holds with the indicator at or near E and you'll have a reference point for future fill-ups.
Old 07-23-2004, 07:06 AM
red95svx
You may have a problem with a sending unit. My 92 gas gauge will read low for a while, then read correctly, then read low.......does yours do this? It is common for the needle to read lower than normal towards the bottom of the gauge. You'll notice that even when you hit "E" you've got a long way to go before you finally run out. Even when the low fuel light comes on you still have 2-3 gallons left.
Old 07-23-2004, 07:59 PM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
Oh so very true... As A Test on my 92 LSL, I ran 40 miles, on E,
BEFORE the Light came on. (40miles in-town traffic mind you)
I think its great that it hits E before your realy low... just so you never do run low! LOL.
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 07-23-2004, 08:14 PM
Whoru465's Avatar
Whoru465 Whoru465 is offline
The name's...
Send a message via AIM to Whoru465
Me too...
I think my guage is messed up as well. I've used about 1/8 of a tank of gas and only gone 36 miles. That sound whacked to anyone else?
-Mike
'92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91
"It says here, 'Breakfast any time'...
That's right...
In that case, I'll have the pancakes in the Age of Enlightenment..."
Old 07-25-2004, 08:39 AM
TonyShaleUK
Me too. I can fill to the brim, the gauge reads just below full. Then, as you drive, the gauge meanders and registers anything from bone dry to full and all points in between!
Is this the voltage regulator or the sender unit?
How easy to get to either unit to check?
Old 07-25-2004, 10:47 AM
Old Fogey
Don't know what to say to Tony or Whoru, but I do recall reading previous threads on this subject, and have experienced the same symptoms as the gauge drops below the half tank mark.
I went to my new service manuals to see exactly what the layout is back there, and a couple of factors appear to contribute to the "wierdness". Firstly, the tank is a saddle tank, with a passthrough/under center section for the driveline, requiring not one but two metering or sensing units, one per side. The fuel pump resides in one side, and there's a "jetpump" in the fuel return line, that uses the flow of fuel back to the side the fuel pump resides in to transfer fuel continually from the other side of the tank, so that eventually all fuel is transferred to the "pump side". As a result, the signal from the two separate senders, "averaged" I assume, may vary as the level(s) in the tank drop. Hope that makes some sense. It would also appear that if one of the two senders is failing your readings would be off.
Glenn
