Stock ECU location
Still got my CEL 45 error - atmospheric pressure sensor.
(anyone managed to fix the same issue on their SVX) Wish to open mine up and check what might be a capacitor issue - anyone know what pin the sensor is linked to ?. TIA
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 06-02-2018 at 01:40 AM. |
Re: Stock ECU location
It's up sort of under the steering wheel area. Small hands and ratcheting 10mm wrench make it slightly less unpleasant...
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com |
Cannot find ECU or atmospheric sensor in section 6 of the FSM ?.
(I have a full set + yearly updates). Anyone got any ideas? also what type of sensor it could be?. TIA
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Unfortunately it says "When trouble code 45 appears on display, replace ECU" ![]() It is inside the ECU housing Here's an old thread on ECU removal: http://www.subaru-svx.net/forum/show...023#post651023
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com Last edited by Stevebsy; 06-02-2018 at 09:43 AM. |
Steve,
found it - yes you are right. Now all I need is a spare ECU from this side of the ditch, so I can PnP with mine, then work through what the issue is with mine? - I suspect dry/leaking capacitor similar to my A/C controller that I fixed a couple of years ago. So has anyone got a spare they are willing to donate till I get mine fixed, will return the unit afterwards - would prefer someone in this part of the world (eg non-USA type with p/n 22611AA710 or 22611AA711). Thanks again.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 06-03-2018 at 05:15 PM. |
So? Does the car run and drive good?
I've been driving my 1992 American SVX with the 'CHECK ENGINE' light on for 10 years...car always runs great!!! ![]() But if it does cause some annoying 'performance' issue while driving, I'd install an inline capacitor to override the problem. ![]() |
The cars drives well, apart from when the weather starts getting a bit cold - hence the atmospheric sensor issue showing CEL 45.
I have now had 2 people here in NZ loaning me 2 ECUs so that I can fault find the issue with mine (really want to keep the original ECU with car). Does anyone know what the atmospheric sensor is / where located / signal type is, to the ECU ?. I am hoping that the issue is a dry capacitor...will keep you all posted.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 06-09-2018 at 11:39 PM. |
