Old 11-12-2013, 10:09 PM
claylindquist claylindquist is offline
Stall after fast deceleration
I have a Stock 1994 SVX. About 3 weeks ago my car stuttered and died after I slowed to a stop on a freeway exit ramp. It has done it a few times since then and all under the same scenarios.
I will be driving around 60-70 and quickly slow to a stop. The car will stutter for about 8 seconds and die.
(additional info) The check engine light has come on 3 times in the last month, but turns off after 5 minutes or so.
Any info or leads would be greatly appreciated. If there is already a thread on this topic I apologize in advance, I did not find it.
Old 11-13-2013, 01:11 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Re: Stall after fast deceleration
I'm no expert on that, but it sounds like the Idle Air Control valve could be the culprit. I would recommend running a search for IAC.
Welcome to the Network!
Old 11-13-2013, 06:39 AM
longassname's Avatar
Just some dude.
Significant Technical Input
I've never experienced or heard of the specific symptoms you are describing but maybe your egr is getting stuck open so you're sucking in uncombustible exhaust gas instead of fresh air? That's really just a shot in the dark. I think the instructions for checking your trouble codes are in the faq section. I'd find them and start with checking your trouble codes.
Old 11-13-2013, 09:14 AM
MCMXCII SVX's Avatar
MCMXCII SVX MCMXCII SVX is offline
I had the same or similar issue with my stock 92 last year. Like yours, it usually happened when stopping at the end of an exit ramp. I'd have to kick it into neutral and then bridge the brake and gas with my foot to rev the engine in order to keep it from stalling out. In my case I also noticed an erratic idle from time to time.
According to the work order, my SVX mechanic found a vacuum leak at the intake. He re-torqued all of the intake bolts which fixed the problem.
Old 11-13-2013, 11:43 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
I had a similar issue to your's. I'd check what the posts below say IACV and EGR just to be sure. What I had to do was replace my MAF. My car would run great at speed but when I came to a stop it would have erratic RPM, sometimes even die if I didn't put it in Neutral and accelerate while on the brake. Also the CEL would come and go every couple minutes. Just an Idea. Good luck!
Sam
Old 11-13-2013, 11:47 AM
Thanks for all the responses!!
I talked to a mechanic friend of mine and he was leaning towards the egr valve. I'll take a look at the codes and see if I can't pinpoint something. I'll also try cleaning the egr valve.
