Old 06-04-2020, 07:50 AM
etz bseder etz bseder is offline
Trouble shifting to D. Brake Sensor??
I’m looking at a 92 LSL. The guy says it has trouble shifting to D and he has to push the lock button. He says is’t maybe a brake sensor.
Does this sound right to anyone? Can anyone help me with what a repair would look like? I’m handy and have owned two other 92s in my years and can do the work and would like to fix it.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 06-05-2020, 02:31 PM
SVX_MY_BABY's Avatar
Re: Trouble shifting to D. Brake Sensor??
I've been told it's a shift lock solenoid which is weak.
Peter
Old 06-05-2020, 03:36 PM
irox irox is offline
It could also be something related to the Shift Lock Control Unit (this is under the center console). On my previous SVX I ended up replacing Shift Lock control Unit, and everything worked find for while, then I ended up replacing the connector on the harness, and everything worked fine for a while. Then I ended up just putting something to block the interlock mechanism.
I kind of suspect that there was a cracked solder joint in my Shift Lock Control Unit, but didn't have a change to diagnose it before I sold it and got a new SVX project. If it pressed on it at a certain angle it worked fine....
There is a little inspection cover just below the hand brake lever, you could pop it open and make sure it's plugged in.
Good luck!
Ian.
