Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Transmission and Drivetrain
Old 02-01-2009, 09:13 AM
Treppiede Treppiede is offline
MT Swap Shift Boots... how's yours?
Fellow SVXers,
I am currently polishing up my baby before reviving her FS thread (), and among the small wrinkles I am ironing is the finishing and installation of the shiftboot.
The reason it has taken me so long is because I wanted it to look perfect, like if it came like that from Subaru (don't we all wish) without the need to cut/widen the rectangular hole on the plastic shifter plate and without seeing any silicone/bolts and such (although a cleanly installed shiftboot with STi-style hex-bolts wouldn't look bad).
I have tried several shift boots and mounting methods and I think I found a reasonably simple, neat looking and inexpensive 'recipe':
  • Black Shiftboot from EG ('92-'95) Civic ($5-10 from eBay/hondamarketplace.com) - guess where I got the idea
  • Aluminium "Carpet Tack Strip" ($1-3)
  • Gorilla Glue ($3-4)
Here's a pic I just took of the boot, secured to the bottom of the plate. All that's left is test-mount the plate to check boot height and stretch in all gears, adjust if necessary, clamp and seal the boot in the tack strip and trim excess.
If successful, I will post pics of the bottom and of the final result so we can share tips and what not. What are your thoughts?
I've seen more than one beautiful SVX with a cleanly swapped MT and strange-looking shift boot adaptations, I really wanted something clean in mine... hopefully it will come out nice, stay tuned for updates.
Regards,
-Walter
1995 SVX Green - now 5spd! ..::|SOLD|::..
1991 Talon TSi AWD (~400 whp pump gas)
1993 Civic CX Hatch (daily driver)
1999 Ducati 748S (built 996 engine)
Old 02-01-2009, 09:22 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: MT Swap Shift Boots... how's yours?
Does your shift lever make contact with the left side of the opening?
Old 02-01-2009, 10:46 AM
Good question. It barely does in 1st and 2nd. I will play with the metal mounting tabs hoping to eliminate it, although it's almost acceptable as is.
-Walter
