Old 01-26-2005, 05:16 PM
sxewhodey's Avatar
sxewhodey sxewhodey is offline
Unhappy Headlight Cleaning site down read only board (cant read)
the instruction site for hosting the write up on headlight cleaning is unavailable. Who copied all the steps. I just got the cleaner ad I need to know what sandpapers to buy.
Old 01-26-2005, 06:51 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Yepp I kicked the server 2 days ago and I have to fix it.
What sand papers? You'll need 400, 800, 1000, 1500, and maybe 2000
Wet sand then use the plastic cleaner
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 01-26-2005, 07:05 PM
Noir's Avatar
Noir Noir is offline
why don't you copy and paste like huck did and put pictures in your locker....unless you think it's privileged information.
Old 01-26-2005, 07:06 PM
sxewhodey's Avatar
where do you get those sandpapers
awfully fine grit. Have you ever used novus plastic cleaning supplies? Do you have it in a word, pdf, or zip file maybe. Just fro oven temps and such. The wife and I are going to try to get paint off my vandalized ones and get em back to new. Any info is apreciated.
Old 01-26-2005, 07:24 PM
sxewhodey's Avatar
Wink Anyone want to split sandpaper cost?
if anyone has found a good assortment pack of fine grit sandpaper at a good price let me know. Or maybe a few people can order a pack a peice and send em out snail mail? I dont want fifty sheets of 1000 grit
Old 01-26-2005, 07:30 PM
lee lee is offline
My local Ace Hardware sells it in single sheets (although not cheap that way), and one of each is more than enough for headlamps.
Old 01-26-2005, 07:32 PM
sxewhodey's Avatar
gotta find an ace
Aces seem to beclosing left and right. Ill try to find a different one close to my house. Thanks for the tip though.
Old 01-26-2005, 07:34 PM
michael's Avatar
michael michael is offline
What Potholes ???
You can replace some of those grits with elbow grease mabey just 800 and 1200 will be necessary. I usually finish with plastic polish, then wax. Somebody verify this, I believe you heat the oven to 400 then turn it off, put the lights in and wait 10 min till you take them out.
Wanted: Steering Wheel
Old 01-26-2005, 08:11 PM
Seraph's Avatar
The difference between Huck and myself is that..... I am usually very busy, I am also very lazy (not that Huck is not busy)
Current SVX: NONE
Old 01-26-2005, 08:12 PM
Seraph's Avatar
Re: where do you get those sandpapers
Do I know Novus? I do. Novus comes after sanding.
Current SVX: NONE
Old 01-26-2005, 08:21 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Sandpaper:
400
600
1000
1500
2000
Alternate sanding direction. If you do 400 left to right, do 600 up and down, then 1000 left to right, etc.
Compounds:
Rubbing compound (Novus #3)
Polishing compound (Novus #2)
Plastic polish (Novus #1)
I used Krylon Clear Coat in a spray can and it has held up for over a year and a half in Wisconsin winters and highway driving.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 01-26-2005, 09:20 PM
Seraph's Avatar
Doug,
call me in the AM.
Current SVX: NONE
Old 01-27-2005, 05:29 AM
mohrds's Avatar
Doug,
call me in the AM.
4:30 AM sound good?
I'll call you around 10
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 01-27-2005, 07:08 AM
sxewhodey's Avatar
Clear Coat?????? Yikes
Man I dont know about some clear coat on my headlights. Thats scary. Maye Ill just saran wrap them, hahaahh JK. Clear coat is strictly for finish or does it protect from fogging, cracks, or any of the above?
Old 01-27-2005, 07:50 AM
mohrds's Avatar
Re: Clear Coat?????? Yikes
Man I don't know about some clear coat on my headlights. Thats scary. Maye Ill just saran wrap them, hahaahh JK. Clear coat is strictly for finish or does it protect from fogging, cracks, or any of the above?
The clear coat protects them from going yellow too quick. You could just use the final polish every month or two but I'm too lazy to do that.
Doug
1994 LSi (4/93)
2000 Ford Excursion
