Old 03-04-2007, 09:27 PM
dmnknightomega6 dmnknightomega6 is offline
Belt woes
I drove
My Accesory Belt with the PS squaeled and broke( It happened a while)
Drove for 12 more miles to get home, quiet and no noticable noise. All temps were normal but the dash was seeing all lights
Turned the pulleys and did not notice resistance nor noise
Is it just the belt? Can it be replaced BY DIY? Point me please and how.
how much is a belt? mechanic fee?
Thanks to the network. I love ya guys.
Old 03-04-2007, 09:51 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
it's not hard to do. pretty much you need a 12mm socket and/or wrenches. you can DIY, it's quite simple. i personally dont know how tight it has to be, i know that there should be some flex when it is right but at the same time you dont it too tight because it will work the bearings harder. i'm sure somebody else would know how to determine the tightness of the belt adjustment
i've had my belts recently changed - last week actually - because of noise. belts will do that.
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 03-05-2007, 12:25 AM
It is not that hard to replace either one of the belts. Go to the How-To Documents to see how to do it. You can also go to this link to see the how to replace the alternator belt. To do the other belt, you need to loosen the AC compressor. Hope that helps some. Good luck.
Old 03-05-2007, 10:25 AM
STORMINORMAN STORMINORMAN is offline
Lightbulb Take a long look at the crankshaft pully...
...because when these go it can toast all the belts, trash your front cover, even get into the timing belt area.
From experience.
Cheers!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
Old 03-08-2007, 12:05 PM
I replaced the belt but still am not sure If I have it too tight. I am getting a squeal when I turn....
How do I look or check the pulley?
Thanks guys.
Old 03-08-2007, 12:14 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Thanks guys.
A bad pulley will be somewhat noticable when turning. You'll see a slight wobble. Tighten a little more if you're squealing. Should be taught bought not overly tight when you press on the open belt area. It can squeal when too tight but usually it'll squeal when too loose.
Old 03-08-2007, 04:11 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Look at the belt while it's running. If it's flapping or slipping, tighten it. You should have a half inch play when you press on the belt between the pulleys (Do this when the engine is off!). Try using belt dressing/conditioner on the belts.
Old 03-08-2007, 04:16 PM
Do you know for sure that it is the belt that is squealing? It could be something else, or another belt.
Old 03-08-2007, 05:41 PM
i was told that belt dressing is not good to use. whether or not i believe that is a different question. but i dont find that it does too much
Old 03-08-2007, 08:47 PM
dannmarr's Avatar
I work for my SVX
I use belt dressing on motor belts on commercial air handler units. This extends the life of the belt. It prevents it from drying out, constricting, protects from moisture and stressing on the pulleys.
