Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 07-30-2005, 12:32 PM
Upgraded Motor mounts???
Who has got em. I am trying desperately to tighten up the slop in my drivetrain. Who is making them, I know a couple of people were looking to do it, whats the status report??
Old 07-30-2005, 04:08 PM
mbtoloczko's Avatar
sans SVX
Did you already take the free play out of the rear subframe mounts? There are two sets of rear subframe mounts and the combined free play is in the range of +/- 1/2".
Mychailo
Visit my locker
Old 07-30-2005, 06:33 PM
svxsubaru1's Avatar
svxsubaru1 svxsubaru1 is offline
how can you take the free play out, subframe bushings?
Old 07-30-2005, 08:59 PM
mbtoloczko's Avatar
sans SVX
Add donut shims to fill the space.
Mychailo
Visit my locker
Old 07-30-2005, 09:33 PM
you mean the X member for the rear diff?? That thing just moves around with no effort involved
Old 07-30-2005, 10:57 PM
mbtoloczko's Avatar
sans SVX
Exactly. All that free play allows the diff to rotate around the axis of the driveshaft. In low gears, that free play is at least in part responsible for the jerky behavior of the car.
Mychailo
Visit my locker
Old 08-17-2005, 03:31 PM
Earthworm's Avatar
Meow!
I've been looking into getting engine mounts made.
Unfortunately I ran into a road block today...they wouldn't be cheap!
I took the ones I got from Subafreak to a local place to see what they can do. These mounts are very complicated and they didn't want to be liable for any damages/injuries as a result of simplifying the mount.
They did say I would need $10000 just to get started on this . I think I'll see what they can do with our rear diff mounts first
Old 08-17-2005, 04:24 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
That's 10000 Canadian though right
Old 08-17-2005, 06:34 PM
mbtoloczko's Avatar
sans SVX
They were trying to scare you off with that number. If someone can get their car over to Dave Clark Motorsports in Kent, WA (can be either a 4eat or a 5mt) for a few days, he can make another set of adapter plates and make up a jig so that he can crank out the adapter plates. I don't think that he would charge more than $100/set for the adapter plates.
It would be great if Earl could drop off one of his SVXes over there. :-)))
Mychailo
Visit my locker
Old 08-17-2005, 07:04 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Would someone PLEASE get an SVX up to Dave's place!!! This is obviously the best solution to this problem, as Dave does excellent work. I'm in for a set.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-18-2005, 12:51 PM
I am saying screw it and going with the Group N mount. It only requires minimal fab and then it will bolt right up. I am in for that. I was under the impression that there were going to be cheaper and easy mounts made but that has seemed to fade off.
