Engine Block
Selling various engine parts.
Engine Block: $200 Plus Shipping (already machined) Crank: $100 Plus Shipping (Already machined) Heads: $150 Plus Shipping (CAMS not included) Factory Pistons: $50 Plus Shipping I dont have the time or money for my project anymore. Everything is up for sale. Last edited by mikecg; 11-24-2008 at 11:36 AM. |
Re: Engine Block
Mike,
Does the block have all new seals? Is it machined for the CP pistons or the stock pistons? What has been done to the heads? What machining was done on the crank? Do you have new main bearing that go with the crank/block? Thanks. -Bill
Re: Engine Block
The block and crank were machined using factory specs. The crank was just cleaned and inspected. I don't have the bearings. The heads have not had anything done to them. However I do have a factory gasket set floating around somewhere. |
Re: Engine Block
Bippity Bump
Re: Engine Block
Bumpin it again. Make me offers. Lots of other parts too. Just ask.
Re: Engine Block
Everythinng is up forsale again
Re: Engine Block
Is this basically a remanufactured block and correctly oversized pistons?
Edit: just read a previous post,...Do you have the full gasket set? It ended up the one I bought has a rod knock on either the middle or back cylinder(when looking from the front) on the driver side although not too bad yet. My mechanic thinks it probably spun a bearing so I am somewhat in need of a motor. Last edited by 1986nate; 11-24-2008 at 11:52 AM. |
Re: Engine Block
The engine is completely disassembled. I believe I have a complete gasket kit, but it doesnt come with bearings. I disassembled it myself and took it to a local machine shop. They machined it to factory specs. same with the crank. The pistons are the ones from the engine and are untouched.
