Changing the fuel tank
The fuel tank in my 92 SVX is all rusty inside and I have found a replacement. How hard is it to replace this tank? I have heard that you have to drop the rear end to get it out. Does anyone have a step by step how to?
Johnny Last edited by svxcess; 02-22-2019 at 10:56 PM. |
Re: Changing the fuel tank
Here is the link to the Fuel System section from the Factory Service Manual. https://drive..com/file/d/0BxZVixvKOy5sd2VYQ2ZlbzN2ZU0/view?usp=drivesdk Covers the removal of the fuel tank. Section 2-8, starting on page 12. Basically you have to remove the muffler and rear pipe. rear axles from the diff, drive shaft, rear diff and rear sub frame. Definitely a two man job and a lift. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-21-2019 at 12:17 PM. |
The tank is plastic, only the metal holding the gauges and pump can rust, and they can be removed and replaced through the access hatch.
That was my first thought exactly... why? I have seen this gas tank out of the car more than once. It is a great, complex design, made of a special high-density polyethylene material that had been in development since 1983. Also has a center layer of nylon fabric for added strength. Resists corrosion, meltdown and blowup much better than a conventional metal tank. Far exceeds US Safety Standards for penetration and fire resistance. They are almost impossible to puncture or damage. Photo below is from the R/T Guide to the Subaru SVX. Section 1. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-22-2019 at 10:53 PM. |
The car I am getting has been sitting for 10 years, I opened the fuel pump access hole and saw tons of rust, the pump and everything around it was rusted, not quite sure if I could just change the pump and stuff and get the rest of the rust out
You should be able to pull all the metal brackets holding the gauges and pumps out, wipe out the tank and replace the gauges and pump from the other tank. Easier than changing the tank.
A wet and dry vacuum cleaner will be your friend. You could buy one as compared with the work involved in removing the tank.
I'm quite sure you're looking for trouble if you use a wet/dry vacuum to suck up gasoline. Once all the gas is gone it could be used for rust particles but be careful of remaining fumes. They are the most volatile.
A good point which should be taken carefully into account. The wise thing to do is first fill the tank with water and detergent to overflowing, drain it and then start from there.
