Old 04-14-2010, 03:36 PM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
From carb to EFI
I have a 1979 Honda Accord, that came with an annoying Keihin carburettor. After a lot of fight i managed to get the thing to work, but i want to take a drastic measure and rethink the fuel system in my car.
Then the idea: Why not electronic fuel injection? The TBI,MPI,CFI as called by GM, VW and Ford is based in a single injector in a carburettor-like body, featuring several built-in sensors of vital importance for the EFI.
So i bought the thing, that i plan to install in my intake manifold with an adaptor plate.
The other things that i have to adapt to the engine are: knock sensor-temp sensor-crank/cam position sensor-O2 sensor.
Other things needed: ECM-wiring harness-external fuel pump-filter-MAP sensor.
I think this is all i need, is there any part needed missing in this list?
As far as i know, the system is fully controlled by the ECM, including the timing but since i will use the original electronic distributor, the ECM will control only the injection. Can this cause an trouble?
Any ideas welcome!
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 04-15-2010, 09:59 AM
MadMaxSvx's Avatar
Re: From carb to EFI
Ok, i figured out the solution: Fiat G6 system, distributorless, with two ignition coils and fully controlled by the ECM.
That Honda will be smart!
95´ Subaru SVX EURO
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
69' Mustang Hardtop
