Old 10-24-2009, 01:16 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Ford Ranger brake problem
Sometimes while coming to a slow stop, the pedal pulsates and goes further down to the floor. It feels almost the same when you have air in the line. I bleed the lines and it didn't change. My rear drum brakes are on it's last leg and I will replace them this week. Would this be the cause for my problem, not having enough pads left? PS It is not the antlock brakes.
Old 10-24-2009, 01:51 PM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Re: Ford Ranger brake problem
How do you know that the pulsations are not caused by the ABS system?
Anyways, pedal going down after a few seconds often means that the main brake cylinder needs repair.
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 10-24-2009, 02:15 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Master cylinder broken?
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 10-26-2009, 08:08 AM
crazyhorse's Avatar
242,000 mi on oem trans
I'm a "Ford Guy", so, I may have a few insights for you.
Check your brake fluid. If your back shoes are thin, then your fluid will be low. This won't cause a pulsing pedal, but it WILL cause the master cylinder to suck air. (causing the pedal to sink like you describe)
Odds are the pulsing pedal is the front brakes....not to worry, unless it feels like the truck is coming apart at the seams. In that case rotors may be the order of the day.
Ford ABS makes a really weird screeching/moaning nose when active. If it were acting up it'd be painfully obvious.
"42"
Current Stable By Age:
Old 10-26-2009, 03:49 PM
AyeJaye's Avatar
AyeJaye AyeJaye is offline
The answer to your problem is on the tailgate. It should even be circled in blue
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle
06 Hyundai Sonata GLS, 77K miles
