Brake Questions
I recently had an emmisions inspection. On the invoice it states my rear brakes are at 5/32 and my front brakes are at 11/32.
What is that measurement? Is it the actual pad? And should those pads' measurements vary so drastically? |
Re: Brake Questions
Front pads usually have more material than the rear to begin with but it really does not matter if they are different. Also the fronts will wear faster than the rears will.
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
Yeah, what Nubs said
Somewhere along the way someone may have put new pads on the front and not replaced the back pads Question - what were they doing inspecting the brake pads during an emissions check?
Yeah, that makes sense. They performed a 27 point safety check, is what it says, free for my safety. They also noted my tire treadware and that my differential fluid is dirty and other such things. I'm wondering, anyone know what measurement should denote replacement of the pads? |
If I remember correctly, there is a wear indicator (basically a small piece of metal that will come into contact with the rotor once the pads wear down) that will give you an audible indication that it's time to replace the pads. The SVX's pads are so easy to change that it's almost criminal to pay someone to do it for you
-Bill
Why did you get an emissions check? Are they required where you are? Or was this part of the 27 point safety check?
You know ... I'm wondering if, at 74,000 miles, I'm about due for resurfacing. (And then there's the weird bird-like chirping I hear from the rear brakes when I first drive off in the morning -- with the brakes unapplied -- as if a caliper wasn't releasing correctly.) Eh, I'm no brake expert, that's for sure. |
Sound from the back could be the emergency brake not fully releasing or, as you've noted, the caliper not releasing correctly.
i'm actually about to replace the brake pads and want to try it myself. does anyone have anything in their lockers on replacing the svx pads? that's not the first time i've heard they are very easy to replace on this car.
Check out Ryan's home page. He has some SVX how-to's on there. There's a good one on how to do the brakes.
http://www.ryanmacdonald.com/car/howto/howto.html He uses the "bolt method" to get off the old rotors that are stuck on. I used the "WD-40 method". It involves using lots of WD-40, waiting about 5 minutes and hitting the rotor with a rubber mallet. Good luck, Matt |
The bolt method is actually pretty fast & simple and coincidentally, the four bolts that hold the two upper radiator brackets have the exact thread and length needed. Just "borrow" a couple of them to pop the rotors off then put them back. And if you're doing the rear rotors, don't forget to release the parking brakes.
KuoH Quote:
