Old 12-03-2008, 05:15 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
overdrive problem ???
Didn't find this on a search, so :
My 96' when it shifts into OD pretty much starts to feel like the car is coming unglued. just starts shaking like crazy. as soon as I downshift to 3d, it all goes away.
-I did get an error code for #5 coil but I can't for the life of me figure out how that would make the car go nuts only in OD.
-trans acts fine otherwise.
-Fluid was replaced 3 years ago along with timing belt, and i do a pan change each time I change the oil.
-no burnt smell to trans fluid
-car has only been driven 200 miles in the last two years, pretty much in (covered) storage while I was in Afghanistan and since I got home.
thoughts ?
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 12-03-2008, 05:42 PM
oab_au oab_au is offline
Re: overdrive problem ???
thoughts ?
I tend to think it is the coil braking down under load, which is increased in 4th gear. Pull the coil and have a good look at the rubber boot, for any tracks (look like a black pencil line) down the boot, inside and outside the boot.
If you find any, scratch them out, and spray it with a silicon oil. If you don't find any, buy a new coil.
One Arm Bloke.
Tell it like it is!
Old 12-03-2008, 06:36 PM
ssnsltd's Avatar
Thanks Harvey- never would have figured a coil could cause the car to shake like that.
I got a complete set of extra coils just in case. once I get back to NY I will put one in and see how we fly.
thanks again!
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 12-03-2008, 08:55 PM
Wikedjuggalo's Avatar
Rebuilding
=D if your around here in NC it will take me 2 mins to pop that S.O.B out =D I just replaced mine... or was it #6... I don't recall lol Driver side nearest firewall.
Old 12-04-2008, 11:08 AM
ssnsltd's Avatar
Thanks for the offer! I am in NC right now- but this car (96) is in NY- so I will B feezin' my fingers off instead of being in a nice warm Auto Craft shop
probably head up in a few days. Also need to change out the rear bearing or HUB complete on my 95 I think I found a complete hub though. I HATE changing out those bearings.
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 12-04-2008, 01:25 PM
Rebuilding
ahh well if ya ever need an extra hand here in NC let me know !
Old 12-16-2008, 01:50 PM
ssnsltd's Avatar
OK, so I replaced what I thought was coil #5, driver side, the one closest to the battery. (based on the pic in my Chilton book.) no real change, and I still get error code P0305.
is #5 on the passenger side all the way n the front
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 12-16-2008, 02:30 PM
ssnsltd's Avatar
OK, in another pic the book shows # as passenger side, against the firewall.
should have known the forst pic was reversed by the way they had the igniter.
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 12-17-2008, 12:03 PM
ssnsltd's Avatar
To close out this question/ thread:
A dying coil/ bad spark will make ones car shake violently when the overdrive kicks in. Never would have figured that.
Got the opportunity to work on the car in 25deg weather- and replaced the #5 coil. The spark plug (iridium) although loose, had good coloring to it so I left it in.
Car runs fine other than it has been mostly in storage 2 years so I have some rust on the brakes to work off. Just passed my NYS inspection Not the best weather to be driving in, but figure I should run a few tanks of gas through it before putting it back in the barn.
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
