2005 Acura TL, 6MT, Navi
Price: $7375
Mileage:145,000 Color: Redondo Red Transmission: 6 Speed Manual Navigation System: Yes Reason for selling: Kid started college. Need to go down to two cars to save money and wife doesn't drive a stick. I will be back in the SVX now and I need to do some work on the car. More about that in another post. Title: Clean and in hand. I believe I am the third owner but I have some records of maintenance of previous owner and all records of what I have done. VIN: Will be provided upon request. Modifications: None Service record: There is ZERO corrosion on the car as I have been treating it yearly with Krown rustproofing. I have been using Valvoline Maxlife FULL synthetic oil in the engine. I swapped in Redline MTL in the transmission. The timing belt, water pump and plugs were done at around 100k miles. The rear calipers and pads were replaced about a year ago. I used the top of the line Akebono ceramic pads. The clutch and all associated parts were replaced about six months ago along with the slave and master cylinders. The master was doing the typical clicking/popping so I just replaced everything at once. Both side mirrors have been replaced due to the typical degradation of the silver coating. Condition: The car has never been in an accident. It has a couple (and I do mean only a couple) of very minor ding and scratches. The cosmetic condition is excellent, inside and out. Other: The car has a sunroof/moonroof and will come with winter floor mats and a spare headlight bulb. Also available is a set of Blizzak tires on OEM rims. One thing that most people don't realize about the 6MT models of these cars is that the front differential is limited slip. It is not just a generic front wheel drive car with an open differential. The traction in snow, for example, is WAY better. Also, the front brakes on this model have big Brembo calipers and large rotors for GREAT stopping power.
