Fuse Box Questions
Question 1:
I heard that in an Outback that you can pull a fuse that can disengage the rear wheels and just make it front wheel drive. Can you do that with the SVX? Queston 2: I was looking at the fuse box and I noticed that on it, it said (Seat Heater). Did they have heated seats in any other countrys or did they use the same box in a different model?
1992 Subaru SVX LS-L #5045 Dark Teal 1992 Subaru Loyale Wagon Gray (SOLD) 1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD) 1969 Subaru 360 Deluxe Ivory White 2005 Subaru Impreza WRX STi World Rally Blue 1993 Subaru Legacy L Wagon Teal Metallic (SOLD) 1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl [SIGPIC][/SIGPIC] |
1 Yes, in the fuse box under the hood by the battery, there is a slot labled "FWD" if you put a 10 amp fuse in that spot it will "Diss-engage" the rear transfer clutchs that drive the rear diff.
2.yes, seat heaters were available in other contrys...including Canada, but not in the USA
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
Thanks alot!
If you look in the outback by the back of the engine bay on the passanger side, there's a FWD pocket for a fuse that disables the AWD making it FWD only. Similarly, the SVX has one in the fuse box under the engine. It's located in the front next to the AC fuse. If you install it, CHECK CAREFULLY when you go to remove it, as if you remove the AC fuse on accident, it will prevent your radiator fans from turning on, your car will overheat, possibly causing engine damage, or in my case, simply blowing the radiator, causing there to be an ERUPTION of water flooding out from your hood in all directions. In my case, it shot out both sides of the car under the hood about 4 feet, getting both the cars next to me nice and wet.
How do you tell if you have heated seats or not?
Where would controls be?
1992 Subaru SVX 1983 Pontiac TransAm 1986 Kawasaki Ninja 600 1991 Eagle Talon TSI AWD |
if im not mistaken either by the window switch or in the coin holder spot
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
