Old 07-13-2015, 06:42 AM
johnnyride johnnyride is offline
SVX and EZPass
Hi all,
Just wondering if anyone else has this problem. I cannot get EZPass to work in my 92 SVX. I have tried two of them. They work in other cars, but not the SVX. Anyone else have that problem? I have tried two of them in the car. Could it be interference with the security system? I'm pretty sure the car isn't made of some allow that blocks the signal!
Thanks, john
Old 07-13-2015, 06:56 AM
processengr's Avatar
Re: SVX and EZPass
Hi,
Do you have it mounted behind the windshield? Do you have the bronze tint?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 07-13-2015, 07:24 AM
Re: SVX and EZPass
Originally Posted by processengr View Post
Hi,
I have it mounted just behind the rear view mirror. And bronze tint? Do you mean up at the top?
Do you think I should mount it closer to the bottom?
Thanks,
john
Old 07-13-2015, 07:33 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Re: SVX and EZPass
Doesn't matter if it is a bronze tint or not. EZPass will not work behind the windshield of an SVX, something about a metallic coating even on the clear windshield. This has been the case for all 3 of my SVX's, none of which had tinted windshields. I have always used the exterior EZPass transducer that is mounted on the top of my front license plate mount.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 07-13-2015, 07:39 AM
Re: SVX and EZPass
Great info. Thank you so much!
john
Old 07-13-2015, 10:32 AM
Re: SVX and EZPass
Yes the windshield blocks it, but the bumper mount is quite ugly. I put mine in the back window between the speakers and it seemed to work well back there. However I no longer live in a area where I am on the turnpike a lot with the SVX so, I generally keep it in the armrest and hold it out the window.
Old 07-13-2015, 01:26 PM
bheinen74 bheinen74 is offline
Re: SVX and EZPass
titanium coated glass is standard.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 07-13-2015, 08:39 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: SVX and EZPass
... or the sunroof.
Old 07-14-2015, 08:40 AM
SVX_MY_BABY's Avatar
Re: SVX and EZPass
Originally Posted by Hocrest View Post
... or the sunroof.
That's what I do Just hold the pass up as I drive through. Locally the commission which gives out the transducers has a list that they check of vehicles which block the signal. Surprised your jurisdiction doesn't. The SVX is not unique.
There was a thread about this quite awhile back. I recall that somebody somehow mounted the pass inside their waterfall grill.
Peter
