Old 08-31-2009, 10:45 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
After months of tinkering with airbag..it's fixed.
This one was a doozie...I have always had a constant airbag light so years ago I removed the lightbulbs in the instrument panel. The dealership at the time could not figure out why my fuses were blowing. They were 5 hours into the job and didn't have a clue. So a few months ago I'd figure I would give it a try again myself. I replaced the CU the first time and it finally stopped my #8 fuse blowing so I could actually read the codes. The old CU had both safety sensors blown.
Once the CU was replaced I was getting #3, 14, 31 codes.
I then proceeded to replace the main harness...pulled out the carpet, glovebox, about 100 screws it seemed. Hooked everything up and got only the #3 and 31 codes.
I then replaced both front sensors...I thought #3 would be solved right? Nope. I checked the resistance and both sensors were infact good.
Code #31 took me to figure out what was wrong with #16 fuse. I checked voltage and found out the small green/yellow wire was bad from the body harness to the fusebox. I made a small jumper from that fuse to the main connector. Success, my airbag codes have all gone away and the light has disappeared.
I thought I would share incase anyone is struggling with airbag problems.
Many thanks to Redlightningsvx for assisting me with interpreting schematics and troubleshooting.
1995 Subaru Svx L / AWD
Old 08-31-2009, 11:16 AM
gbianchi gbianchi is offline
Re: After months of tinkering with airbag..it's fixed.
Wow what good timing, last night I did a search on air bags and got zipp, I also have the A B L on my "parts car", I have not really looked into it as I have zero experience with this stuff, but I was wondering where to start. The car has been in a L F collision but has been repared, although not well, I am thinking front sensors not replaced after the crash. After I swap the tranny I'll dive into that A B L Anyway thanks for the info and good work..........G
I thimk ther4 I an, what? huh!
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
05legacy gt limited "Moon" blue.
06 Subaru legacy gt limited.
Old 08-31-2009, 11:20 AM
crazyhorse's Avatar
242,000 mi on oem trans
And here I was thinking the "Airbag" light had something to do with my wife *HEHE*
"42"
Current Stable By Age:
Old 08-31-2009, 12:43 PM
msvx95's Avatar
It's just a phase
Haha funny....
What year is your car gbianchi? I have an OBD I (pre 96) and I use the test connector provided to read the codes. That's the easiest way to figure out what is going on and to see if your sensors are faulty.
Yeah not too many people on the forum with airbag issues. I went elbows deep into this one.
Old 08-31-2009, 04:01 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Glad to hear we finally found out it was a stupid wire.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-31-2009, 04:04 PM
msvx95's Avatar
It's just a phase
Yeah tell me about it...how long is our PM trail about 25 messages?
Ok off to put the radio back in AGAIN!...LOL
Old 08-31-2009, 04:14 PM
I'd say more.lol Just happy this whole ordeal with airbags is over and you know ALL your bags are working properly now.
Seth
Past subies:
Other toys:
Old 08-31-2009, 05:12 PM
msvx95's Avatar
It's just a phase
Agreed...next up are sway bar bushings and I see an oil leak near the cams ...ugh
Old 08-31-2009, 10:28 PM
SVXalter's Avatar
SVXalter SVXalter is offline
Wow I wish I had time and a location to do all this... My airbag light has been on for 2,000 miles or so now. How long did it take you to do everything?
Old 09-01-2009, 04:42 AM
msvx95's Avatar
It's just a phase
Well I had to work on mine in my apartment parking lot...LOL
I really don't know how long. I would say about 4 full months from the day I really started taking it apart. I took it apart originally..fixed what I thought was broken, then found out that wasn't the problem so I put it back together in frustration and left it alone for 2 months. Then recently wanted to get it fixed again.
Realistically I saved hundreds if not a few thousand dollars on doing it myself without having a tech or suby dealership do it. Airbag parts are very expensive if you have to buy new.
Old 09-01-2009, 12:52 PM
Originally Posted by msvx95 View Post
Haha funny....
Car is 92 obd 1, what connector are you you referring to, thanks ........G
92legacywagon"snow"
84Brat"huey"
Old 09-02-2009, 05:04 AM
msvx95's Avatar
It's just a phase
In the picture attached it's figure 6
A black 10-pin connector and you should have two black w/blue strip wires near it to plug into any of those pin terminals.
It's under the kickpanel fusebox.
Old 09-03-2009, 03:49 PM
So you are using the check engine connector to check codes on air bag light??
More info please, I just learned how to diagnose CELs for the engine!!! "NEWBE"
Thanks .........G
92legacywagon"snow"
84Brat"huey"
Old 09-03-2009, 04:09 PM
That plug is used to diagnose a lot of things including the airbag system.
Seth
Past subies:
Other toys:
Old 09-03-2009, 06:37 PM
msvx95's Avatar
It's just a phase
Oh yeah I love that connector!
For airbag diagnostics stick one of the leads into the #9 terminal to read the codes.
To clear the codes plug one lead into #3 and one into #9
