Old 03-23-2001, 10:13 AM
249SVX 249SVX is offline
still in love with Hannah
My sun roof sticks when it rains. After it drys out a little it will open, but this time it didn't. It will open with a little nudge but not by itself. Would it help if I lubbed the seal arround the edge of the roof?
silver 92 SVX-"Hannah" -R.I.P. NOV. 1991-jAN. 17, 2003
red white and blue 2000 Suzuki TL1000-r-"Bethany" This grips me more than a muddy old river or reclining Buddha.(now running Metzlers!
black 1987 Toyota MR2-"Helga" -Turbo conversion will now commence.
1996 Legacy Outback-"Gilda" white with brown trim
Old 03-23-2001, 10:18 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Yes, the lube around the seal might help. This was a problem addressed by a TSB on the '92's. Mine does the same -- unless I'm up to road speed -- then, the downforce aids in opening/closing. I used a silicone gel called Sil-glide I purchased from Autozone. This is also a good product to have around for winter. If you smear a little on your door seals during winter, it keeps them from freezing. It may also help to clean your tracks for the sunroof. They can get quite "gunky."
Oh, and I almost forgot, if that doesn't work, you can try adjusting your clutch nut on the sunroof. It's under that stopper, just behind the dome light. It won't move much, so, be careful. A slight adjustment is "a lot."
Randy Johnson
Mike Davis -- at Reading VI
Old 03-24-2001, 08:22 AM
Ok, I'll give it a go after I do my brakes today. Thanks
Old 03-24-2001, 10:22 AM
I'll have to try it tomorrow, I only got one side done today and now I have to got to work. I did learn that the parking brake is a drum brake. Now I will know to DISENGAGE the darn thing when I take the rotor off.
Old 03-24-2001, 01:21 PM
Aredubjay's Avatar
Yep, another one of those little "subaru engineer" surprises -- The "drum in disc" brake. It can be a rude awakening for those unfamiliar.
Randy Johnson
Old 04-04-2001, 07:42 PM
Joe 90's Avatar
Joe 90 Joe 90 is offline
Canadian eh!
Wink "drum in disc" brake
<< another one of those little "subaru engineer" surprises -- The "drum in disc" brake>>
Actualy, this system is widely used on cars with discs on all corners.... It makes it simpler to have the hand brake in a small drum than directly on the caliper...
Remember the GL10 hand brake on the FRONT WHEELS...?! Now that was weird!!! You had to "screw" the pistons back in when replacing the pads...
Old 04-04-2001, 07:59 PM
immortal_suby's Avatar
Thread Killah
Yeah, I remember the first time I put brakes on my old wagon, we had a lever bar on a C-clamp trying to compress the piston when a neighbor says, "I think you have to turn it while pushing it in on those old subarus"
Locker Link
2015 BRZ Limited 6MT
Old 04-04-2001, 11:06 PM
Joe 90, where did you get that little picture at?
Old 04-05-2001, 04:36 AM
Joe 90's Avatar
Canadian eh!
249SVX, do you meen my "cartooned" teal SVX.... Well I created it.... I've been doing these "car-toons" since I was a kid...
Old 04-05-2001, 11:35 PM
Yes, that's pretty darn neat!
Old 02-21-2006, 10:05 AM
Old 02-21-2006, 12:30 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
99-04 Mustangs were still using that awesome technology
I found out the hard way just like you..
Brian
