Stupid window tint
My SVX has the back and rear side windows tinted, what's the best way to get it off? I figured heat gun for the side windows, but I'm worried about messing up the rear window defroster so I'm not quite sure how to get the rear tint off...
Heat gun it then pull it off? The worst part isn't the tint, but the sticky mess it leaves behind. Some people don't have a problem with it, but I actually found it so difficult to remove I just left the goop on one of my windows.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
Ask a tint shop what they use. I thought it was a solution that is just sprayed on and let it set for a little bit. Then the tint peels right off.
My sidewindow tint is tearing all apart, so I'm wondering the same thing.
Acetone is usually what Tint shops use to remove it, but it never hurts to get some other ideas from them.
Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
My son is a professional tinter and this is what he does
for the back window remove the film layer by just pulling it off then use Fantastic brand cleaner with a light duty scrubby pad to remove the residue it takes quite a while it depends on what brand of tint was used as to whether the defog lines will come off you'll know right away as the lines turn a different color 3M tint usually pulls the defog lines off use a razor blade and Fantastic for all the other windows. Good luck ![]()
92 SVX LS Pearl 94 SVX LSi Barcelona Red 82 Brat 4WD Bob |
use a fingernail to lift a corner and just rip it off. The gooey mess left behind dissapears with mineral spirits, any kind of goo gone, or even wd-40. you'll want a nice fine edge to scrape the stuff off...but dont use a razor blade, especially on the rear glass, because you'll run the risk of either scratching the glass, or DEFINENTLY scraping off the defroster lines. a credit card works alright, but best yet is a bondo spreader.
FYI I used acetone and a razor blade on my windows and still found it difficult enough to just give up. The adhesive on your tint may vary in strength...
I attribute one part of the problem to the acetone evaporating too quickly. "Fantastic" may not have this problem.
Also depending how long the tint has been on the glue might be there forever ![]()
I'll have to try that. I doubt it's 3M window tint as it's faded.. It is a well done job, so someone knew what they were doing, but it's cheap tint, so you can't see through it very well, and it's purplish.. Otherwise I'd just leave it on... Thanks for the tips, I'll give it a try tomorrow and see how it goes...
I may have to get mine off as well after my little run in with the law
For my side windows I used a razor and rubbing alcohol. For the rear, I did some research and found this method recommended most.
QUOTE: "Put some ammonia in a spray bottle and heavily spray the rear window tint, then immediately push the black plastic up against it, it will cling there. Shut the car and all the windows and leave it sit in the sun for 30 minutes. Get in open the doors and windows, and use a plastic scraper."
This method should loosen the old tint, making it much easier to remove. I do, however caution you about using ammonia. You should wear both eye and breathing protection when using ammonia in a closed environment. Be sure to ventilate the car while you are inside spraying. The ammonia smell will linger but with proper ventilation it should be gone in a couple of hours. As for removing the glue/bonding material, try "Goof Off" a product made to remove paint and varnish spills/overspray. It should do the trick, and you should not have to scrape the residue, just wipe it off with paper towels. As Hocrest says, cover and protect your interior pieces. Best wishes. Preston |
Hmm... Bright sunny day. Oregon. November. Probably not going to happen anytime soon
Use goof off or goo gone it gets all the sticky mess off quickly
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
