Part number needed-trans cooler lines
Does anyone know the part numbers for the hoses that run between the two steel lines for the trans cooler, right behind the LH head? My parts catalog doesn't show them.
Re: Part number needed-trans cooler lines
i relpaced those with standard oil hose, just cut to length. They dont have much molding in them, thus standard hose will work fine....
92' Claret LSL 282,000 miles 1owner(ME) 07' Pearly WRX 40k Cobb Stage II (sold) SVX+$$$+GreaseMonkey = |
45521PA031...Hose ATF Inlet...$27.50...(number 5 on the diagram) 45521PA041...Hose ATF Outlet...$48.41...(number 6 on the diagram) It is located on the Subaruparts website. It is in the Engine Cooling [2] section of the 1992 SVX. http://www.subaruparts.com/diag/?mod...category=450-B .
thought he was refering to #7 in diagram( "hoses behind LH head")>.......
These hoses attach directly to the transmission on the driver's side. .
I just used regular hose on mine. I had to make a loop in the hose to keep it from kinking because of the angle.
