Old 05-01-2022, 07:40 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
RIP power steering?
Hello - after 22+ years of service, my power steering has stopped working recently. (LSL type) Seems like there is either none, or very little assistance.
Stuff I know:
1. Plenty of fluid at the proper level doesn't seem to be leaking.
2. Crank pulley is aluminum, so it's not the rubber thing slipping problem
3. Power steering light is not on.
4. Belt is tight, pump is spinning fine
5. No noises or such
6. O-ring was replaced a few years ago.
22 years is not a bad run, but what/how else could I check before replacing the pump? I suppose it could possibly be the rack. Neither have been changed since I got the car in Jan 2000.
Thanks for any ideas
'20 Honda Ridgeline
http://www.x35design.com
Old 05-06-2022, 06:48 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: RIP power steering?
Stuff I know:
I recently bought a rebuilt rack. I thought it had issues as I was experiencing chunky steering. Turns out it may have been the crank pulley. I replaced the clearly failed pulley and things got better buy my assist is still weak and a little chunky. So, either my pump is failing or the rack was rebuilt like crap. I am guessing it is the pump. I get the occasional belt squeal. Do you?
Tony
Old 05-06-2022, 07:21 AM
Stevebsy's Avatar
Administrator
My crank pulley is aluminum. (I had the slippy pulley issue years ago and got the aluminum one instead)
No squealing or other issues... It seems like I get a small bit of boost but not nearly what it was before.
'20 Honda Ridgeline
Old 05-07-2022, 05:26 AM
You both should make sure the u joints from the steering column to the rack are in good shape. Resistance before the rack will never be overcome by assist from the rack
Old 05-07-2022, 03:35 PM
My '92 got really stiff at slow speed quite suddenly. I found a wire hanging down under the dash near the TCU. When I reconnected it my power steering worked again. It was obviously a wire for the speed compensated steering.
I also had stiff U-joints on the steering shaft. They made the steering very notchy.
Old 05-11-2022, 07:26 AM
Did you lube them or replace them?
Tony
Old 05-11-2022, 05:01 PM
I lubed them. First with WD40 and then oil. They were good for quite a few years until I sold the car.
Old 05-15-2022, 06:59 PM
wdb wdb is offline
dances with roads
Good stuff here.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 05-22-2022, 08:23 PM
THE NEW GUY THE NEW GUY is offline
You are the best, man.
