Sigh.
It was going well too. I have done a quick search, but what does it mean when the anti lock brake light comes on and the ABS unit under the bonnet starts buzzing? I have disconnected the battery for now, to stop the buzzing. I assume that the unit has just self destructed. Any positive words? Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com |
Re: Anti-Lock Brake warning light and buzzing noise
It's just a sticking ABS relay. A simple solution where you probably don't have to replace anything. If the relay needs replacing, it is very simple. Instructions and part numbers in the link below.
http://www.subaru-svx.net/forum/show...94&postcount=3 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-04-2012 at 07:04 PM. |
Don't know for sure, but I thought that, the relay was just a normal Bosch relay.
Thanks for the help, lads!
I have struck it with my knuckle. It seems to have fixed it!!! THANKS AGAIN!
![]() helps relieve frustration and sometimes fixes things too ![]() |
This problem just happened to me. Gave it a rap as suggested and it's fixed for now. I love it when a little aggression actually fixes a problem...
Also, this is why this site is so valuable. Got my $ worth annual dues and it's only March. Thanks for the resource. ![]() |
Wow, had to pull the ABS fuse for this on Friday and haven't found time to diagnose. I bet my problem is exactly the same because the pump kept running even with the ignition off.
What a coincidence ![]() Tapani |
I pulled the fuse and it kept going! So I ran in to the computer and looked it up. fixed in 5 minutes.
/T |
No. Pulled the 20 amp ABS fuse. It kept buzzing with engine off.
Had it happen again, except I did not hear it and it drained the battery. Thinking I should replace it.
