Old 11-21-2005, 10:47 PM
damein730
a different tranny problem
ive been searching and seen alot of tranny problems but none like my car. it just wont shift out of first. i have park and first every thing else is like nutral what do you think this could be
Old 11-22-2005, 03:41 PM
damein730
some one please help if you have heard of any one else with this problem. i did a code check and it gives me code 11
Old 11-22-2005, 03:43 PM
damein730
if you know where i can buy the soleniods for the tranny please give me a direct link i look on subaru parts and couldnt find them
Old 11-22-2005, 04:00 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
http://www.subaruparts.com/diag/?mod...category=182-A
part #2 (i don't know what year yours is, this is for a '92)
Old 11-22-2005, 04:06 PM
oab_au oab_au is offline
Is that first gear in the D position, or first gear on the shift lever. Does reverse work? Do the dash light change when you move the shift lever?
One Arm Bloke.
Tell it like it is!
Old 11-22-2005, 05:09 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
Unless I let my car idle for about 15 minutes it wont come out of first unless I manually shift it from 1st up to 2nd.... Im thinking I have the same problem.... Oy I guess the solenoid bananza begins here...
Old 11-22-2005, 05:15 PM
Boxer6SVX's Avatar
$317!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!! What!!!!!
Old 11-22-2005, 05:17 PM
Earthworm's Avatar
Meow!
How's the transmission fluid level?
Old 11-23-2005, 03:27 PM
damein730
tranny fluid is good and clean do you think its a seleniod problem
Old 11-23-2005, 03:31 PM
damein730
it goes threw all the positions on the dash. no reverse D is 1st / 3 is 1st / 2 is 1st / and 1 is 1st / nutral is nutral and / reverse is nutral / park is park
Old 11-23-2005, 03:51 PM
intelisevil's Avatar
<<<Alcyone
If the lights on the dash are controlled by the tranny computer, (that would be my guess), it sounds like the computer isn't telling the tranny to shift?
Do you have access to another computer to swap in?
Good Luck,
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 11-23-2005, 03:55 PM
<<<Alcyone
I'm sorry, I just reread your post . . . You're saying it DOES go through all of the positions on the dash display but the tranny is staying in 1st gear.
Dan
Old 11-23-2005, 04:19 PM
damein730
yes it does go thew them on the dash
Old 11-23-2005, 09:45 PM
It looks like a Sprag one-way clutch in the box has failed. It holds a part from rotating, so the drive passes through. When it fails, the part rotates, and there is no drive. Except for 1st gear that uses the low reverse clutch instead of this sprag.
Take it to an auto transmission, or ring them, talk to them about it, see what they say.
One Arm Bloke.
Tell it like it is!
