Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 09-25-2006, 10:06 PM
gsrsol84mm gsrsol84mm is offline
Question When does the timing belt need changing ?
Has 112K on the clock. Checking the prior owners dealer's records, the timing belt was changed at 85K. When would it have to be changed again ?
Thanks, Wayne
Old 09-26-2006, 05:20 AM
Should be good for 100k, as long as you don't have any major oil leaks up front......but doubt your waterpump will last that long
Old 09-26-2006, 08:02 AM
gtdanielgt's Avatar
gtdanielgt gtdanielgt is offline
I miss my VR-4
Send a message via Yahoo to gtdanielgt
Heya Huck,
Mine was done at about 68K and I have 115K on there now.. It HAS been 6 years since it was done though. I am planning on doing the timing belt with a tune-up as well in a month or less. Would you suggest replacing the water pump at that time as well even if it's not bad?
Thanks a bunch
-Daniel
Insert Witty Quip Here...
No more subie
Current Cars: 96 Chevy Caprice Impala SS clone
93 Chevy Full-size blazer
Soon: 2002 Honda CBR 954RR
Old 09-26-2006, 08:21 AM
Originally Posted by gtdanielgt
Heya Huck,
Thanks a bunch
-Daniel
I would, as several people have had the water pump go out at around 120-130k, and if it goes while you're driving it, it can cause t-belt idler bearing failure, and end up costing more to repair later.
I'd recommend cam seals and crank seal and water pump if you're doing a t-belt and have over 100k on the motor.....the seals are only a few bucks...
Easier to do it all while it's apart than tearing it down twice...
Old 09-26-2006, 01:04 PM
Thanks for the help. Any idea what's a reasonable cost to do the timing belt, water pump and seals ?
Wayne
Old 09-26-2006, 01:12 PM
Wayne
I usually charge about $125-150 (plus parts)....Subaru charges about $450
Old 09-27-2006, 06:51 PM
Huch,
Do you have the part numbers for the cam seals and crank seal. Would you get all the parts at subaruparts.com or where would you suggest. Thanks again, Wayne
Old 09-27-2006, 08:28 PM
The part number I have for the cam seals is 806732150...don't know if that's a subaru number, as I got them from a local parts place...
I can't find the number for th ecrank seal off hand..
As for cam and crank seal, and timing belt, I'm happy with my local parts place, water pump...OEM is great, but a well done rebuilt one should be fine also.....at least to me.
Old 09-28-2006, 05:17 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Correct
That is the correct Subaru number for the cam seals. They are the same as for the Legacy.
Lee
Old 09-28-2006, 09:11 PM
Ordered the parts from Subaruparts.com. Spoke to Trish, very friendly and helpful. Waterpump $95.97, Gasket $2.01, Timing Belt $76.16, 2 cam seals at $6.11, crank seal at $5.64, all OEM new parts. I also decided to replace the Alt belt $13.68 and power steering / AC belt $22.82. Found a mechanic here who will do the whole job for $200.00
The car made it on 112K with the oem water pump which still works. I will stick to OEM. NAPA wanted $136.90 for the water pump. I also ordered the oem top and bottom radiator hose to do at the same time. This should nip some potential problems in the bud.
The tranny is a newly rebuilt Cottman ( Previous Owner), so I will install a B&M cooler and frame mounted filter as well. Try and make the tranny last.
Starting to really like this SVX
Wayne
Old 09-29-2006, 05:07 AM
Sounds like you're off to a good start on your preventitive maintenence
Old 10-11-2006, 06:08 AM
Well the mechanic finished the job yesterday. He was cursing a little bit as he said he wouldn't do the job again for that price. I did cringe a bit when he said the water pump he took off looked new, ouch !!! I knew the timing belt had 30K on it as I had the receipt from the previous owner. She was not sure about the water pump and I could not find it on the work receipts she gave me. Looks like the crank and cam seals were replaced as well. Oh well ! at least I know everything is changed with new OEM parts. Put in the Stage 2 ver 6. ACUtune and it's like a new car. Could not believe the difference. Seems to pull 25% more and no hesitation. Next is new OEM shocks and Dayle's lowering springs , tranny cooler and filter and I'm done.
Old 10-26-2006, 11:11 AM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
where about in NC are you, i need a cheap mechanic and i think i might want to replace the water pump/ timing belt soon
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 10-26-2006, 12:53 PM
n00b on demand's Avatar
My water pump went out at 121k and it was the original. Do the oil seals...timing belt and water pump and you will not have to worry about anything for a longggggg time.
Old 01-12-2007, 01:05 AM
svxboy svxboy is offline
Send a message via Yahoo to svxboy
long lived timing belt
Well, my SVX has 194k and I have owned it since 33k and it still has the original timing belt and water pump which operate fine. I just wish I could say the same for the front seal, cam seals, and valve cover gaskets. They are leaking like crazy! I popped open the timing belt cover and the belt still looks good too, unbelievable! I have all the parts, just gotta find the time to tear into it.
Greg
92 Teal SVX LS, Superwhite headlamps and front turn signals, Premier DEX-P1R Deck, A/D/S P850 and Earthquake 200DHC amps, PG Bass Cube, 3-10 in. Diamond Audio subs, A/D/S 346is front components, and Vifa rear 6x9's. B&M tranny cooler and temp. gauge. Flowmaster custom dual exhaust, Tenzo-R conical intake filter, JC Sports torque chip, and a Mid-Height wing for an Integra that fits perfectly and stands 6.5 in. tall. ART front and rear cryo/slotted rotors, SS brake lines and EBC "Green Stuff" pads. My email address= fastestsvx@yahoo.com
[IMG] code is Off
