Old 12-09-2006, 08:45 AM
95greensvx's Avatar
95greensvx 95greensvx is offline
Tension Pulley
While replacing my power steering pump and after I was done I went to tighten my power steering belt. While doing this the bolt was stuck for some strange reason and then broke in half and it screwed up the threading within the part that connects into the pulley. I am not sure where I can get this small part and a new bolt and I was wondering if anyone on the boards would happen to have any advice as to where I can get a new or used tension bolt and the part that connects into the back of the pulley? Thanks in advance.
Old 12-09-2006, 09:20 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
dealership should have it or should be able to get it... auto parts stores are kind of hit or miss... they may have it if its the same thing as the ej22's but the dealership is going to be your best bet
- John
Old 12-09-2006, 05:36 PM
nysvx10 nysvx10 is offline
Did you loosen the bolt in the middle of the pulley before trying to tighten the belt? If you didn't, make sure you do once you get it fixed.
