Go Back   The Subaru SVX World Network > FAQs, How To's, & Vendors > How-To Docs & FAQs > Technical Service Bulletins
Old 04-20-2010, 08:40 PM
How-To Doc How-To Doc is offline
How-To Document Administrator
Turn Signal Operation
Author: Subaru
NUMBER: 08-32-94
DATE: 02-14-94
APPLICABILITY
97-MY-93MY SVX
SUBJECT:
PREMATURE CANCELLATION OF TURN SIGNAL LEVER
Affected Vehicles:
All 1992 SUBARU SVX's
1993 Subaru SVX's up to P*101119
If you encounter a customer complaint of a turn signal lever that prematurely cancels before the turn is fully completed while turning right or left, it will be necessary to scrape some plastic material from the combination switch bracket stopper with a sharp scraper or a knife.
  • Tools needed:
  • Phillips Screwdriver
  • Sharp Knife or Scraper
Repair Procedure:
  1. Verify concern.
  2. Remove upper and lower column covers.
  3. Locate the area to be scraped using Figure 1. The material that is to be removed is shaded light gray in the Figure.
  4. Scrape 0.1 to 0.3mm (.004 to .012 in.) thickness and 1/2 in.in length for right turn cancellation and 1 in. for left turn cancellation from the bracket stopper. See Figure 1.
NOTE: If the repair is performed for a premature cancellation to the left, the wire harness will need to be temporarily removed from its holder and reinstalled after proper operation is confirmed.
  1. Remove all scraped material.
  2. Replenish grease as necessary.
  3. Recheck turn signal for proper operation.
  4. If operation is normal, reinstall upper and lower column covers.
FLAT RATE INFORMATION
