Trans Temp Gauge
I would like to install one. Any recommendations on where and which one to buy? Where to hook up (hose, hard line, filter, pan)? Where to set up the gauge? Photos would greatly be appreciated! Thanks in advance.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
Re: Trans Temp Gauge
ensteele installed one from Dakota Digital. Photos and write-up on installation HERE Dakota Digital has Odyssey Series I and II, as well as traditional round gauges. Well-made, attractive and accurate. http://www.dakotadigital.com/index.c...=cat/cat70.htm .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
I don't know about what kind ( brand ), but as far as where the gauge (s ) should go, I personally like them easily readable, but non intrusive. How often do you use the CD player?
Google " 1 din gauge pack or pod " ... 52 mm fits in a 1 din space, and is a very common size. You can get 3 ( I think ) where the CD player now sits. Not that this is what I'd recommend, but as an example of what gauges are available, colours and lighting options .. http://www.ebay.com/itm/06-08-Mitsub...4e8267&vxp=mtr Or, if you want and excuse to put the Panasonic factory Subaru stereo in a box for posterity, and put in an Android based double din stereo, there are integrated apps so that you see the gauges on screen, Torque,an android app, for example, hooks into OBD 2 and uses the info to display. It'll also talk to an android phone, if just occasional checking is all that's required. No stereo needed. Google says there's similar for OBD1 systems. "Evil McGuyver idea".. Don't know if this is do-able.. but anyways.. The SVX has two coolant sensors, one for engine management, and one for the gauge on the dash. Now, as far as we all know, every SVX and many, many other cars, have a "dead zone" Now the question is, is the dead zone a product of the sensor, or the gauge itself? Either way, my idea would be to simply mount a factory coolant sensor in a sensor mounting block in the cooling line exiting the transmission. Run the 2 wires from the engine coolant temp sensor and the 2 wires back into the car and to a double throw toggle switch. run the output from the toggle switch back to the wiring harness connection for the engine temp sensor. Now, theoretically, you could toggle the dash gauge between trans temp and engine coolant temp. Maybe a spring loaded momentary switch ( hold for trans temp ). Although most temp gauges have a dead zone between 180 and 205, they seem accurate outside of that zone. Checking them against the "other" sensor via the OBD port may be helpful in interpreting the dash gauge readings. That idea came to me while I was typing about the Bluetooth stuff, because, although cool looking, it didn't address your original post, which was a trans temp gauge. Yeah, I thought, too bad there's no way to get the trans temp signal into the wiring harness.. hey wait a minute! what if we... so that's where that idea came from. There may be a few reasons why it is absolutely not recommended, and I'm sure if there are, someone who knows why will kindly post them.. So Ummm... don't start on that just yet LOL.. But hey, ya never know, if it's a viable alternative.... It'd be one easy way to monitor transmission temp. |
I have the sensor in the pan drain plug and the Marshall Instruments gauge where the ashtray used to be.
Do a search, there are photos somewhere. /T |
Did you drill and tap into the plug? Or do they sell them ready for a sensor?
Drii & tap. Do a search. T
