Old 01-11-2006, 07:05 AM
DavieGravy DavieGravy is offline
Sqeaking belt and discolored ps fluid
Sometimes when I start my car up cold and turn the wheel really far in one direction, the serp belt squeals. When I straighten the steering wheel out, the squealing stops. When the car warms up, the squealing doesn't happen at all. Just curious how tight the belt should be. I've heard about a half inch of play. I don't want to tighten it up too much and damage the pulleys.
Also, ps fluid (dexron III) appears very thin/watery and has a milky-white coloration to it. I don't think it's aeration as there are no bubbles in the fluid.
I just recently replaced my pump and the fluid is new. Any thoughts on these issues?
Thank you.
Out for good.
Old 01-11-2006, 07:54 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
If you recently changed your belts, are you sure the serpentine belt driving the ps pump is tightened down properly? There's a lock nut on the front of the tensioner pulley that many forget to tighten.
-Chike
2006 Steel Gray WRX TR (sold)
Old 01-11-2006, 01:52 PM
Earthworm's Avatar
Meow!
I would change the o-ring if you haven't already, flush out the fluid and if it still squeals determine which pully is squealing.
It could be the pump seizing up, the tensioner pulley bearing failing, the crank pulley separating or the belt wearing out.
Old 01-11-2006, 03:02 PM
I would do what David has suggested. I would be a little worried about the condition of the fluid.
Old 01-11-2006, 03:04 PM
oab_au oab_au is offline
Thank you.
Davie, as you say "when I start my car up cold and turn the wheel really far in one direction, the serp belt squeals" This is pretty normal in cold weather, if the belt is loose. If it has a 1/2" play, it is too loose. When the wheel is turned to the stops, it hits maximum pressure, to open the pressure relief valve, and the belt will slip. Worst when the oil is cold and thicker.
The milky appearance of the ATF is due to the water that is in it. Drain and refill, tighten the belt and all should be OK.
One Arm Bloke.
Tell it like it is!
Old 01-11-2006, 06:47 PM
Water probably got in there when I hosed off the engine. I'll do as you suggested. Thanks!
Out for good.
