Old 03-08-2021, 12:48 PM
wdb wdb is offline
dances with roads
SVX 5-speed manual on BaT
This one looks familiar, and even mentions a thread on this forum:
https://www.subaru-svx.net/forum/showthread.php?t=50837
https://bringatrailer.com/listing/1994-subaru-svx-12/
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 03-08-2021, 04:04 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Re: SVX 5-speed manual on BaT
Yep. It's mine temporarily. Letting it go again. Check out this video from Rich Chen, the interim owner between my 2 periods of ownership
https://www.instagram.com/p/Bik6CU2lqCl/
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 03-09-2021, 04:59 AM
Why are you selling it after so recently purchasing it back?
Old 03-09-2021, 01:07 PM
Don't drive it that much any more. Have retired from the track and I wanted to get an electric vehicle. I love the car, but it just doesn't fit that well into my life any more. If it does well on BaT, then selling it will not cost me any money.
Old 03-09-2021, 07:17 PM
Good luck seems like the prices have jumped up and there has been more interest in the last few years. So it is probably a good time to sell.
Old 03-15-2021, 03:36 PM
$14,000 Wow not bad!
Old 04-02-2021, 06:23 PM
wdb wdb is offline
dances with roads
Prices have jumped up on everything. I guess those work lunches everybody isn’t buying must have been deluxe!
